IM 9000 Fusing issue
  • Old Crow
    • Aug 2011
    • 203
    Originally posted by copyboy99
    by any chance are you using correct power cord, 15a vs 20a, recently on one new install newbie tech some how manage to use 15a power cable sent by mistake from warehouse, had similar issue, after replacing entire Fuser Assembly, couple of boards, finally Team lead went on site and found wrong power cable, hope this would be helpful.
    Good question...not sure. One thing I was thinking to check when I go back was voltage at the wall. Could be the cord instead? Thanks for this...will let you know.
    • luca72
      • Oct 2017
      • 1780
      You can see the real Power supply voltage on display during work by SP...but for me the problem its in the web cleaning unit, its the more weakness ring of the chain.
      "I'll be back"
      • Old Crow
        • Aug 2011
        • 203
        The cord is correct and wall voltage not dropping, trying to get whole fuser with web ass'y. to experiment with.
        • Ajester
          • May 2011
          • 5
          #19
          I had an IM9000 at a prison unit. It had the same issues of not fusing the toner to the paper, and no service codes. The power at the wall between the two legs was questionable. But there was defiantly a voltage issue between the ground and one of the legs. This allowed the machine to come to ready but did not code, and caused the poor fusing. Dirty power.
          • luca72
            • Oct 2017
            • 1780
            #20
            you made me doubt, didn't I ask you which country you are in?...if you are in Europe, the voltage is 220v, in the USA it should be 110v as far as I know...if you are in Europe, someone before you, may have mounted one or more lamps with different voltages by mistake.
            "I'll be back"
            • Old Crow
              • Aug 2011
              • 203
              #21
              Went back today to double check all, tried a different circuit, where a MP8001 is running fine, also 120V, 20A...no help. Yes, we are in the US. Will look closely at the lamps again.
              • GIUBOSS
                • 1435
                #22
                Try another original toner.
                • luca72
                  • Oct 2017
                  • 1780
                  #23
                  So...how did it end?
                  "I'll be back"
                  • Old Crow
                    • Aug 2011
                    • 203
                    #24
                    Gonna try new dv and toner.
                    So...how did it end? : Thanks for checking...still ongoing, waiting on a fuser ass'y. Will let you know how it goes.
                    • KeviM
                      • Oct 2019
                      • 324
                      #25
                      Hi everyone
                      Maybe try checking your pressure on the pressure roller and the lift motor and gear assembly. Also check springs on pressure roller.
                      Check bushings and bearings in the fuser. Make sure they haven't jump off position
                      Check pressure roller metal cleaning roller. It could be dirty.
                      All the best friend
                      • Old Crow
                        • Aug 2011
                        • 203
                        #26
                        Originally posted by KeviM
                        Hi everyone
                        All the best friend
                        Thanks for the input, yeah we looked at all stated but will double check.
                        • KeviM
                          • Oct 2019
                          • 324
                          #27
                          Sorry Sir. Please keep me posted
                          • tonerhead
                            • Sep 2009
                            • 582
                            #28
                            Although they are likely marked per color on the lamp holder, I have seen techs put the lamps in wrong positions before. It will come to ready and run, but not fuse properly.
                            I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
                            Especially when it comes to sex
                            • Old Crow
                              • Aug 2011
                              • 203
                              #29
                              Thanks, will check that too.
                              • Ajester
                                • May 2011
                                • 5
                                #30
                                I had the exact same issue a couple weeks ago. Poor fusing. BUT the machine eventually threw a SC547 code. The FU1 on the PSU was blown. I have had many situations like this, and replacing the fuse has fixed my issue. I ordered them on Amazon. Bojack 5x22mm 8A-250V. I hope this helps.
