IM C300 Printer error
  • semi
    • Sep 2008
    • 195
    Hi all, customer is getting this error:
    Customer getting this message -IM C300:
    ERROR:
    MemoryFull
    OFFENDING COMMAND:
    STACK
    This is printed out on the device & the job is cancelled- also some borders are missing when printing PDF invoices.
    No solution installed- firmware up to date package 8.01 - machine has been fine for 3 years, their IT dept says drivers all up to date, happens on various workstations but not all the time- any ideas? Poss HDD??
    • 37560
    3 year old machine could be a failing HDD. Could also be memory errors. Try clearing printer function memory with SP 5-801-008 and Printer SP 1111-002.
    How long ago was the firmware updated? It could be firmware corruption. In the past that required reflashing using SD card module firmware.
    • sandmanmac
      • 3985
      ERROR:
      MemoryFull
      OFFENDING COMMAND:
      STACK
      Which Drivers? The proper and full PCL6 driver, or the universal P.O.S. that will cause all kinds of errors?
        • 8195
        Check if all drivers are printing via IP you may have one PC using a WSD port.
        www.printerfirmware.co.uk
        • luca72
          • Oct 2017
          • 1791
          # year old machine could be a failing HDD. Could also be memory errors. Try clearing printer function memory with SP 5-801-008 and Printer SP 1111-002.
          +1 ...its happen to me same thing on a 2003, 2 day ago...its a good idea try to replace it
          "I'll be back"
          • semi
            • Sep 2008
            • 195
            Firmware updated last month when the issue first appeared- again this week, checked all work stations all printing via TCP/IP Ports full PCL6 driver- going back tomorrow , will update.. will try SP 5-801-008 and Printer SP 1111-002.
            • ridgemill
              • Sep 2017
              • 191
              Log into the web image monitor, go to Device Management > Configuration > Security > Network Security, and turn off IPP Port 631 on IPv4 and v6, and turn off all WSD on both IPv4 and v6. This should disable all WSD and IPP printing, so only TCP/IP printing will work.
              This should eliminate any problematic printing queues. If it still occurs, there may be a Microsoft Class or Ricoh universal print driver installed.
              Do not disable IPP port 80, this will prevent you from using the web image monitor, if it is turned off, you have to telnet into the IP address and run set http up to re-enable.
              • anothertech
                • 1771
                Could be a workstation printing to the machine by mistake, using another manufacturer print driver. It's not easy to tell where this might be coming from. Change the IP address and update your workstations.
                  • 37560
                  If the IM C300 Printer function can display the Job queue, it is easy to determine where the job came from.
