RICOH Firmware Update Tool allows users to install firmware updates themselves.
  • DRichard
    • May 2008
    • 482
    Re: RICOH Firmware Update Tool allows users to install firmware updates themselves.
    Originally posted by KenB
    I think the engineers need to come out of their bubbles and experience what's happening in the REAL world.
    Bubbles, hell... many of them won't even get out of their CHAIRS...
    "Enjoy every sandwich."
    -- Warren Zevon
    • anothertech
      • 1757
      If a machine has Streamline or and other Java apps running I do not touch the firmware. As long as it's running I leave it alone. All other Ricoh machines I work on, I turn on auto update SP5886-111 and turn off java SP5730. If the machine does not have auto update, I update it with ARMS if it's on @remote or I use the SD card method if it's not. Once the machine is up to date, it's easy to keep it updated as you go.
      I've not had a problem with buggy firmware except for a few times with Streamline, so I don't do those units anymore.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3945
        It used to be that if there were any Java apps installed that they needed to be removed before updating Java, and reinstalled afterward. It was a colossal pain, to say the least.
        That has not been the case for a few years now. You should be able to update Java and not break any apps. A few years ago, I updated Java on several hundred MP 4002s at one account, all were running eCopy ShareScan Embedded. It did not break any of them.
        Streamline now only requires Java on non-SOP machines. Not sure of the exact model cutoff/breakdown...that always seems to get complicated. Since Java is going bye-bye, no MFP apps should require it anymore.
        Although rare, there have been a few cases where newer firmware messes Streamline up, but that normally only comes into play when different updates are mixed and matched, not updating all of the effected ones at the same time.
        There is definitely something to be said for package firmware...it gets 'em all.
        • Gift
          • Mar 2011
          • 2457
          #19
          Originally posted by dave w
          It works a treat.
          But allowing the customer to have the ability to do the FW updates themselves!
          Would you trust them?
          Im not sure I would trust my customers.
          Nice one, just did a test in-house and an update on a MPC3001 went well. I do have some more Ricoh MFPs in our network but I can't discover or specify most of our units even if I can ping them and enter the web interface.
          Is there any admin setting needed to make all units wrk with that tool?
          Edit: my fault - seems we have some different log in credentials
          • sandmanmac
            • 3973
            #20
            I also discovered the solution to the issue I had (and posted about here the other day) in discovering a particular model.
            I had not really gone through the settings on that machine as I would before delivery, and it turns out, several settings in the network Security section were inactive. As soon as I activated them (other than WSD), I was able to discover and update the F/W with the tool.
            I haven't bothered to try and isolate the exact module, so I can't say which one specifically cause the issue
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              #21
              Personally I would always do firmware my self with sd card knowing a customer they will update and thinking its taking to long then switch machine of by mains firmware is are job
              Regards Mark
              • dalewb74
                • Feb 2018
                • 1125
                #22
                customers don't even know how to put toner in the copier. so yeah i wouldn't trust them do a firmware update. and as was pointed out the flaky firmware that ricoh puts on the site is.......
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  #23
                  Anything xx04 and above has the Application Site where the customer can do the package themselves anyway, not had one bugger a machine up yet.
                  Hit it.
                  • Gift
                    • Mar 2011
                    • 2457
                    #24
                    I think this one is to consider for some large accounts with own (and competent^^) IT departments.
                    • rthonpm
                      • Aug 2007
                      • 2847
                      #25
                      [ATTACH=CONFIG]49889[/ATTACH]
                      It's SSDP (Simple Server Discovery Protocol) that needs to be enabled. I tried enabling all of the functions I had disabled on our office MP 171 and then trying to connect. If it didn't make a difference in connecting, the service or protocol was disabled again. Once this was enabled, I was able to connect to the machine.
                      • sandmanmac
                        • 3973
                        #26
                        Thanks.
                        Good to know.
                        I typically enable everything other than WSD on every one of my units so I hadn't bothered trying to isolate.
                        I also (coincidentally) had a call on an old MP171 myself today, and decided to try an update using the tool, and it worked flawlessly.
                        Again, I'll never advise my clients do this, it's just an excellent tool for me to use myself going forward, and I'm so thankful it was introduced in this thread.
                        I'm typically only dealing with small workgroups that have a single machine, to a few machines at most, so for me, it's great!
                        • rthonpm
                          • Aug 2007
                          • 2847
                          #27
                          At the same time, with SSDP disabled, you also have a great safety feature to keep customers from trying to update their machines.
                          Sent from my BlackBerry using Tapatalk
                          • anothertech
                            • 1757
                            #28
                            This is a great tool for all of the techs that post here looking for firmware, it is now available to everyone for free.
                            • Gift
                              • Mar 2011
                              • 2457
                              #29
                              Yes indeed and it is pretty idiot proof, too
                              • satins
                                • Feb 2021
                                • 89
                                #30
                                It works a treat.
                                I recently had an experience with the firmware update tool. We wanted to upgrade the MP6001 to accept SMB 2/3 protocol and as informed from the CTN community, a customized firmware existed. After help from the professionals we were able to load the firmware and make the SMB V2/3 work, all good, right! No, not yet, afer the customized firmware was loaded we went again and connected the device to Firmware utility and updated it with the latest avaliable on their website and guess what the latest firmware did? It closed the SMB V2/3. Luckily for us, we realized that the changeover will do more harm than good and downgraded it to customized firmware again to make SMB V2/V3 work.
                                I have mixed feelings about this now, as I can imagine the challenge it can pose if, it were to happen to large number of machines in the field that too being upgraded by customer itself.
