Imc3000 drums in imc5500
  • Timmytronic
    • Oct 2010
    • 249
    Hiya Folks
    is there a quick fix to make the IMC3000 PCDU units work in the IMC5500. I accidentally got IMC3000 and canโ€™t return. Only found out this morning at a customers ๐Ÿ™ˆ.
    I know we use to switch a cable at the back on the MPC range. Black is fine mind.
    thanks loads. Tim.
  • GIUBOSS
    • 1435
    Originally posted by Timmytronic
    Hiya Folks
    thanks loads. Tim.
    You can try it at the moment of discovery and answer your question ;-) , only the black unit is the same while the colors are not
    • fummbles
      • Dec 2010
      • 22
      Did it work?
      • Popolopo
        • May 2023
        • 133
        Deve Unit for colour is different.
        • copier tech
          • 8144
          Maybe the PCU will fit just not the complete PCDU ?
          โ€‹
