Aficio 1224c Error code Sc544
  • h.lubecks
    • Jun 2025
    Hi intelligent people,
    I have an Aficio 1224c and, it was working fine until I changed the password for operator tools, 2 min, after that a windows test came out, it was less dark, after that I have this message: code SC 544
    the button of the printer is lighting red, and a service key is also lighting red.
    can I rest this, and if the thermostats are defective, where can I find them?
    I don't have the service manual, only users manual.
    thanks for the help,
    greetings, Hans.
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    greetings, Hans.
    • h.lubecks
      Thank you for your fast replay,
      but I don't have a service contract, and it is very expensive for me now to get one.
      I have some knowledge about electronics, just don't know where to look!
      I don't know it is possible for me to get the schematic drawings for this machine? or a manual that can help?
      greetings, Hans
      • Zoren
        Technicien de copieur
        • 99
        like the 1st reply says, it does not concern what u changed when that code appeared... only a power surge can trigger a fixing error... unless u were unfortunate that a thermistor went open.....
        try to reset the machine first. before you tear apart your fixing unit
        Just came out from hybernation.....
        • h.lubecks
          • Zoren
            • 99
            im not familiar with Aficio 1224c if its the same procedure with other ricoh digital models when resetting error codes but you can try...
            But if these hardwares you mentioned have a problem, you wont be able to reset it just like i mentioned in your PM.... better ask a copier tech'n to check it first....
            • gstaylor
              • Mar 2009
              • 12
              How to clear SC544
              Hans,
              Im guessing from your posts that your not a trained tech, so let me laymans terms it for you.
              SC544 is a fuser error and as said previously has nothing to do with your password change.
              The SC544'A' is a code type 'A' which means it will not clear by itself, it needs a technician to reset it.
              If you want I can talk you through re-setting, but it will need to be over the phone as it will take a few minutes and is to long for this post.
              Please feel free to give me a call (my number is at www.inception.co.uk).
              If your not from the UK, our UK code is +44 and drop the 0 at the start of the number.
              Regards
              Gareth
              _____________________________________________
              Knowledge is knowing a tomato is a fruit.
              Wisdom is knowing not to put it in a fruit salad.
              sigpic
              www.inception.co.uk
              www.inception-store.co.uk
              • fitsy.13
                senior tech
                • 64
                its not a high temperture it low temp on the fuser unit enter the service mode which is 107 and the clr buttton press copy mode then 7 data log and scrol down to sc-reset
                turn machine of and on
                • h.lubecks
                  Thank you all for the help,
                  the reset was successful, it works again OK!
                  • Eric1968
                    • 2458
                    I don't think it's a good idea to tell a non-tech the way to enter the service mode. The service mode is for technicians who know what they're doing, not for customers!
                    You can do a lot of damage if you don't know what you're doing!
                    You can simply reset the 544 Service Call, but what caused this SC??? I bett this SC will return.
                    • KopyKat
                      Nurse Ratched of Repair
                      • Nov 2008
                      • 366
                      I'm with you on this one. SP's are for trained techs.
                      sigpic
                      Relax! This firmware injection won't hurt...but it will take 45 minutes.
                      • h.lubecks
                        You are wright, some one who don't have the knowledge, will damage his machine, I also think he will not be able to find this forum. Eric1968, for your information I am an engineer in mechanics, electronics and computer sciences. it is just I don't have the technical schematic drawings of the machine, so I am not some one in a office behind the books, I know what I was doing.
                        and everyone repeated that my changing of the password has nothing to do with this problem, I was just putting the moment that the error acquired in view.
                        I was overwhelmed when I saw how much response I had from people trying to help me. The people that help other people just from the goodness of their hart, will not be forgotten,
                        what goes around comes around.
                        I will later update my profile so you know what my knowledge is, if someone needs help in that area and I can help, I will be glad to do so,
                        thank you all,
                        Hans
                        • Zoren
                          • 99
                          no guts, no glory man......
                          • h.lubecks
                            I know the reason of this error, I live in a place in Belgium, where the power is very unstable, time to time you see the light strength change, so what I think is I was operating the machine, then a paper with windows test page came out, and very clear, no one was printing anything, so it had low temperature and it trigger the fueser, it is working fine now, I will put an UPS on the machine so it gets constant power.
                            what do you think?
                            • fitsy.13
                              senior tech
                              • 64
                              what do you think?
                              to right we are here to help each other
