How can I scan to a folder?
  • Lider
    • Oct 2024
    • 5
    Hello everyone. I have a Ricoh 7502 model machine. I want to use the scanning feature. I used it before, but after formatting my computer, reconfiguration was required. My computer guy has now closed his business and we are not in the same city. My settlement is a bit small and I am having problems getting technical support. Could you please tell me step by step what I need to do?
  • Lider
    • Oct 2024
    • 5
    I created a file on my disk. And I opened it for sharing and gave the necessary permissions. I use wireless internet on my computer. But there is a switch between my computer and the machine. Believe me, I have no idea what path I should follow... :/
    We had previously performed an installation via FileZilla. I wanted to edit it again and add it in case it might be useful to say this.
    • Popolopo
      • May 2023
      • 133
      You can try this method
        • 37488
        Originally posted by Popolopo
        Does not provide the most important first step, TURN ON FILE AND PRINT SHARING! That is probably why FileZilla was used before. FileZilla 9s an FTP server instead SMB. Follow the attached document from Ricoh.
        Win7_Win8.pdf
        • luca72
          • Oct 2017
          • 1778
          try to use this, I've never used it, but I've heard people here say it works.
          "I'll be back"
          • Lider
            • Oct 2024
            • 5
            Thank you guys for your help, but let me explain it to you more clearly. I provide the connection between my computer and my machine with the help of a switch. We can print when we give the IP we gave to the machine to the switch. Likewise, we can log in to the Ricoh interface. (Web Image Monitor) But we don't know the username and password. We type admin as the username and leave the password blank and we get an error. That's why I want to scan using FTP over the IP and switch we have assigned. I know it's very confusing and bad
            • luca72
              • Oct 2017
              • 1778
              at this point it's quicker to send you this video than to explain the procedure, may work on that model too.
              when it asks you leave the password for "supervisor" blank
              "I'll be back"
              • dalewb74
                • Feb 2018
                • 1153
                Originally posted by luca72
                i have seen it work most times. but rare occasion it doesn't always work.
                • dalewb74
                  • Feb 2018
                  • 1153
                  no matter which method you try to setup the scans. at some point you have to have access to the web image monitor. this is so you can tell the copier where to direct the scans. i have never used filezilla on a ricoh, only on kyocera. i use either use the scan config tool for ricoh. or i it up with the other method listed above. and as slim mentioned, make sure those permissions are on. and some firewalls will block it, your IT might have to allow the scans. i have also seen typically what someone says is their antivirus. but it also has a firewall that blocks it.
                    • 37488
                    FTP confusing, NO. FTP bad, extremely. It is the least secure method of file sharing. If that switch is connected to the internet you expose your computer to every hacker in the world by installing an FTP server.
                    • Lider
                      • Oct 2024
                      • 5
                      Hello. I did the steps in the video one by one. I activated SMB 1.0 and walked through the video step by step. Everything is great, the file where my scans will go has also appeared on the machine. But I get network wall error from the machine. I granted all necessary permissions from the network sharing center and turned off the firewall. I scan but I can't import the pdf to file. Where could the problem be?
                      • Lider
                        • Oct 2024
                        • 5
                        Yes, I somehow gained access to the web image monitor interface. I did everything in the video suggested by our other friend who tried to help. I do not have antivirus, my firewall is turned off, SMB 1.0 is activated, the file is shared safely. I wonder if I'm having this problem because I didn't set a password for the new user I'm sharing files with?
                          • 37488
                          If the MP 7502 cannot be upgraded to SMBv2/v3, be aware that every time Windows installs an update it will turn SMB1 off. You can however use Scan to a Memory device, see operator instruction manual. That takes the network out of the picture entirely.
                          • dalewb74
                            • Feb 2018
                            • 1153
                            yes that windows turning off my share settings is a pain in the ............
                            and yes the one setting this up. you gotta have the user id and password, most cases.
                            • JonManchester
                              Technician / Shop Manager
                              • Aug 2013
                              • 103
                              For what it's worth, I tried years ago to get into web image monitor on an MP6002. After typing admin for username and leaving password blank, I clicked the enter key and got an error. After messing with it for awhile knowing the password wasn't changed I typed admin and left the password blank, then with my mouse clicked the ok key and it worked. WTF right.
                              Live for something or die for nothing.
