Ricoh MP 6002, MP7502, MP9002 Family Series, Lights or low density Copies or printing
  • mterrero
    • Sep 2011
    • 60
    [CQ] Ricoh MP 6002, MP7502, MP9002 Family Series, Lights or low density Copies or printing
    Hello, has anyone finally found the cause of this failure? Some say the ID sensor, others say the machine filters, others change the developer unit and the developer, and the problem still occurs. When you do (force toner supply), the machine returns to good quality for aprox 150 - 200 copies, in my case I have tried changing the toner feeding mode to (pixel count) and still nothing,
    has anyone solved this problem?,
  • luca72
    • Oct 2017
    • 1778
    hi, the causes can be multiple, (otherwise it's not fun), how many prints does your machine have?
    if it has more than 1000k it is usually enough to change the developer unit, and the developer, others say the toner supply clutch, however there is also a somewhat dated technical bulletin that suggests changing some values in SP to try to compensate for this problem .
    It depends on how many prints the machine has, and the life of the consumables.
    however you must necessarily update the firmware, because a new sp has been added which allows the fan to better cool the drum and everything else to minimize the deterioration of the toner and developer within the unit.
    clean the drum's external air exhaust ozone filters at each intervention
    SP 3-990-001 =0/1 (fan rotation speed)
    0=slow (same of previows firmware)
    1=super turbo mode (ver. 1.03 or later for light print)
    *be careful! with setting 1 the machine could move around the office by it self...LOL
    "I'll be back"
      • 37487
      The very first thing to do is check SP 3001-001. It should be around 70. If it is much over 100, you have a problem with the ID sensor. All Martini series models have a problem with leaking toner out of the drum cleaning station and guess what is right below it, the ID sensor. Recommended cleaning method is with a camera lens blower brush. Other methods of cleaning can damage the sensor and require that the sensor be replaced. If the problem returns quickly, replace the cleaning brush.
      • mterrero
        • Sep 2011
        • 60
        Thanks for your contribution, I have a question, do you think that in pixel count mode, the ID sensor should still operate? Or is it just the TD that doesn't operate?
          • 37487
          IMHO pixel count should only be used if you have a bad ID sensor and/or a bad toner density and have to wait for parts. It will by default under tone.
          • luca72
            • Oct 2017
            • 1778
            "I'll be back"
            • dalewb74
              • Feb 2018
              • 1153
              well the counter sheet that you uploaded showed the machine is pushing over 2 mil. what have you done maintenance wise on this machine?
              • mterrero
                • Sep 2011
                • 60
                Hello, The drum is almost New OEM < 50K, The Developer unit was changed complety, Developer powder is OEM, <90K, quality is excelent after a force toner Supply, Firmware was updated with the lastest version using the Ricoh Software Tool..
                Yesterday I Changed the ID Sensor, The ID reading was 50,
                The problem is that It is not Feeding the Toner Automatically as It should...
                I will change the Fan setting you indicated, forgot to mention that the machine is on a hot environment 35 celcius ( 95 F) or more
                • mterrero
                  • Sep 2011
                  • 60
                  maintenance is up to date, New Transfer Belt, New fuser components, New drum oem <50k, Developer oem <90K , Developer unit Changed ( complete ), Develeper powder <90K, Charge corona wire ( Changed )
                  • mterrero
                    • Sep 2011
                    • 60
                    ID senson changed yesterday, lets see what happend today..
                    • stephaneleclere
                      • Sep 2008
                      • 15
                      If ID sensor don't solve the problem, I will try to change the piezo toner end sensor on the toner supply unit.
                      • mterrero
                        • Sep 2011
                        • 60
                        That was changed with the Developer Unit..
                        • stephaneleclere
                          • Sep 2008
                          • 15
                          OK. I thought they were 2 separate units.
                            • 37487
                            OEM or Genuine Ricoh? There is a huge difference in quality and testing. Forced toning should not be needed with new Genuine Ricoh development unit and developer.
                            That is beyond specified range of 32 celcius ( 90 F).
                            • dalewb74
                              • Feb 2018
                              • 1153
                              have you already used the cleaning rod on the drum lenses?
                              guess you know that these have been discontinued?
