IM C3010 firmware E32 error
  • slot
    • 341
    just setting uop a new machine did the firmware and ended up with E32 error
    Is there a way to reset the firmware running like the old machines i tried reset 143 ccc and hod but you dont get a beep to say its done ?
    anyone know if thi still works on the new machine or if im doing it incorrectly
    • 8144
    Happy to help with your firmware needs.
    www.printerfirmware.co.uk
    • sandmanmac
      • 3981
      I got locked out of an MP C3004 during a F/W update some time ago and thought it was bricked - until I came across this thread where Deb1964 posted a GENIUS solution that saved my life. (I miss Debs)
      Scroll down to find her fix - the key for me was the 5 minute wait.
      https://www.copytechnet.com/forum/te...out-mpc5504-ex
      ALSO....the original poster (Vintage tech) posted a follow-up because in his case some icons didn't return afterwards, and he posted the fix for that.
      Good luck!
        • 8144
        Good luck!
        Has Debs retired ?
        • sandmanmac
          • 3981
          Has Debs retired ?
          I don't know her personally, and I'm unsure of her status - only that she's not posted in quite some time.
          She really added a lot of excellent insight and is/was a valued member
            • 37487
            Has Debs retired ?
            Looking at her Profile she last posted here on July 31, 2024. Her last Facebook post was September 18th when she updated her Profile Picture. She turns 61 tomorrow so might be retired.
            • slot
              • 341
              Thanks for the link we DOA the machine I had tried c1243ccc but only with the package .
              I'm not sure it that workaround is on the new machines as it never bleeped at me while holding down the c key
              • sandmanmac
                • 3981
                Wouldn't beep on me until I waited 5 minutes either.
                BTW.....you don't hold the c button at the end of the sequence. That may be part of the issue
                • slot
                  • 341
                  Maybe my error I always thought you had to hold the c down on the last pres until it bleeped to say it had reset the error flag
                    • 8144
                    Yes, also this is the wrong number sequence, there's no number '2'
                    • slot
                      • 341
                      Sorry the 2 was a typo error fat fingers
                        • 37487
                        That is why I proof read everything. And still occasionally one slips by
                        • RandyW
                          • Jan 2013
                          • 213
                          Were you able to reset the code? I didn't think the newer machines had many individual firmwares and only a handful to update. Had to use Package firmware.
                          I'm trying to remember to format the SD cards before using them (they are already formatted just been used several times).
                          • Ricoh-ono
                            • 338
                            The individual .FWU files can be extracted and placed in a romdata folder using the 7-Zip software.
                            Do what you can, with what you have, where you are. ~Theodore Roosevelt
