Screwdriver of choice - Ricoh
    • 37049
    #16
    Re: Screwdriver of choice - Ricoh
    Originally posted by rthonpm
    The lengths of the screws may be different, but the head is the same size. Years ago I had one of the 5.5mm Ames Supply screwdrivers, which was the most reliable one I've ever had. Left it at a customer and never figured out which one so I've had to make due with a few others since then, going to check the recommendations here since the magnets in my current set are far too weak.
    Sent from my BlackBerry using Tapatalk
    Ames Supply/West coast Platen does have a new website but are mainly parts and refurbished machine for a few printer lines. No tools that I can see. West Coast Platen
    • KeviM
      • Oct 2019
      • 324
      #17
      THe only thing that I have encountered that uses a different size than 5.5mm is the Plockmatic. A number of different thread sizes and types but all 5.5mm heads.
      Thanks. This is really helpful. Need to get 1of these as well
      • Imprestik
        • Aug 2012
        • 296
        #18
        On all Ricoh devices all you really need and what I carry is the following,
        PH2 Phillips head in both 100mm and 200mm blade lengths
        5.5mm Hex head (nut drive) in both 100mm and 200mm blade lengths
        I use Wiha which is made in Germany. Had them for 17 years and haven't failed once. Awesome piece of kit.
        • anothertech
          • 1757
          #19
          I have to keep a separate Dr bag tool kit for Plockmatic, everything is different.
            +1 on Ames
            • KeviM
              • Oct 2019
              • 324
              #21
              My boss has a similar story, he was fixing a Nashua (Ricoh) copier at a client had the machine apart and his tools out and then realized he has to put money in parking meter on the ground floor. Goes to put money in the meter and when he comes back his Snap-on screwdriver was gone. Someone there took it. No-one admitted to taking it. Anyway that was a $90 screwdriver gone.
              • MitchD
                • Oct 2012
                • 164
                #22
                I have had the Ames 5.5mm since the mid 2000's and it has been by far the best tool in my bag. It fits the Ricoh screws perfect and has a great magnet for holding the screws. My whole dept uses them. its a shame you can not get them anymore. I lost it once and was completely devastated! Turned out i left it in my pocket and it fell out in the car under the seat. I was beyond relived when I found it cleaning out my car at the end of the week!!! Whew!!!
                "Heavy music to the normal ear is nothing but a loud annoyance. Most people think of it as obnoxious, talentless music but to someone who really listens and is really in love with music knows how beautiful and amazing it can be" Tommy Rogers of Between The Buried and Me"
                • luca72
                  • Oct 2017
                  • 1710
                  #23
                  Originally posted by KeviM
                  Not to sure if this is the right section for this but...
                  For Ricoh machines what is your recommended screwdriver of choice?
                  I'm currently using a CK Philips 2 x 250mm shaft, overall length is 350mm. Using this for more than 15 years. It's a good screwdriver but it cams out alot. I read that JIS might be better.
                  Thank you in advance
                  I use since 2002, Black & Decker PP360LN lithium, equipped with long tip insert, like a manual screwdriver, I only changed the battery once, sturdy, lightweight, and easily repaired in case of breakage, my wrists thank
                  "loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
                  • techandtrader
                    • Jun 2016
                    • 318
                    #24
                    My Driver of choice for everything is the Snapon Ratchet I use Ames / Wira for the long mag hex screw work.
                    I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
                    • tonerhead
                      • Sep 2009
                      • 582
                      #25
                      Similar story. I was taking apart a machine in a manager's office. All of a sudden he comes in, has to take a call, asks me to pack up pieces and get out of office. I packed up all of the pieces and did the repair in the reception area. Get done, he is still on call. He is not to be disturbed. He finally finishes. I put the machine back and said in my hurry I had a screwdriver and flashlight on the table in his office. He tells me I must be mistaken, I did not. That jerk robbed me of my 10 inch ames philips and my mag light flashlight that day. Still pisses me off. Hope he enjoyed them, the jerk, the manager yet, I still don't believe it.
                      Side note, I've always used B/D power screwdrivers, the 6v pivot plus. I had 2 of them, each lasting about 12 years. Great tool, but ni-cad batteries so eventually quit charging. Now I went cheap. Bought a 4v lithium for $14.99 at WalMart 2 years ago. For the money, not a lot of power, but holds a charge forever and gets the job done, would buy another in a heartbeat.
                      I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
                      Especially when it comes to sex
                      • allan
                        RTFM!!
                        • 5461
                        #26
                        Not this again.
                        Whatever
                        • KeviM
                          • Oct 2019
                          • 324
                          #27
                          Originally posted by allan
                          Not this again.
                          Sorry. Just upgrading the screwdriver so checking for some advice before I do.
                          • allan
                            RTFM!!
                            • 5461
                            #28
                            I am an old school guy when it comes to this. Use a wiha PH2 x 350mm had a 400mm German one before.. Gives you lots of torque and hand feel. Electric just is to bulky. When it comes to speed i do ok with the old screwdriver.
                            Whatever
                            • KeviM
                              • Oct 2019
                              • 324
                              #29
                              That's 1 of the brands I'm considering. Just wondering if it grips the screw head well
                              • allan
                                RTFM!!
                                • 5461
                                #30
                                Yes it fits the screws well and its quite affordable. Been using the same one for years now.
                                Whatever
