Image problem on a MP7001
Regards Mark
https://copierservices.simdif.com -
Re: Image problem on a MP7001
thanks! ... at the time I had thought about it ... but I had not found the sp, usually, on any model, if the sp is present, I always increase the operating time of the drum exhaust fan, just to avoid these kinds of jokes, and that of the fuser, to avoid deformation of the fuser covers, and paper guide...we have had a lot of problems in the past."I'll be back"Comment
Thank you, thats the sp i changed i but i wasnt remember it well and yes the machine has all the new software udate.Comment
Actually you can, i am using it only if a drum has humidity problems to save it, most of the times works fine, i remember using brasso for selenium drums for cleaning purposes we had a lot of FT 6750. (what a headach those machines were.......jesus!!!)Comment
Just to clarify:
Is this darker area (compression?) crossfeed (A4) or in the feed direction (A4-R)?
If it's crossfeed (main-scan, A4) ... and I think it is ... we used to see something called "developer burn", in which the selenium drum coating was damaged by incorrect charge values or excessive internal heat, usually prematurely. In this case the band crossfeed would move around on the page. Does the anomaly stay in the same position relative to the leading edge? In that case, perhaps you have a fuser speed issue.
If it's in the feed direction (A4-R) that's an entirely different story. So which is it? =^..^=If you'd like a serious answer to your request:
It is a normal paper, i think i remember that, it was a problem because the client was making mostly duplex copies and that was causing heat inside the machine........Just to clarify:
If it's in the feed direction (A4-R) that's an entirely different story. So which is it? =^..^=Comment
The ft7650 I also know Martin series replaced by martini very similar and both have OPC Drums not selenium totally different surfaceRegards Mark
https://copierservices.simdif.comComment
I seem to remember something about the cleaner for selenium drum if used on the wrong type of drum could release poisonous gas.Comment
