Sc 66x occurs - sp mode displayed in japanese
  • RMC8112
    • Nov 2019
    • 38
    Has anyone came across this? I have a customer who has this on their IM C3000. I've replaced the BICU and the BCU, but still getting it even after resetting the SC code. When I go into SP Mode, i can click on system but can enter any values. rfg083871.pdf
  • sandmanmac
    • 3973
    Re: Sc 66x occurs - sp mode displayed in japanese
    Originally posted by RMC8112
    Has anyone came across this? I have a customer who has this on their IM C3000. I've replaced the BICU and the BCU, but still getting it even after resetting the SC code. When I go into SP Mode, i can click on system but can enter any values. [ATTACH]50337[/ATTACH]
    I can't respond to you based on experience, but which of the MANY 66x-xx codes are you getting, because there are very specific references listed in the SM based on the sub-code, and several different PCB's that could be the culprit -although there is no BCU on this machine, so I'm not sure what you actually replaced.
    Typically it seems to suggest replacing BICU / Imaging IOB / Paper transport IOB (in that order)
      • 37052
      You've got the bulletin, why don't you just do what is says? Or do you lack the service manual?
      • anothertech
        • 1757
        All the PDF says is to refer to the manual, they could put out a PDF for every code there is and it could just say the same thing...refer to the service manual.
          • 37052
          A couple of other things the TSB tells you:
          1. It tells you what is causing the error code.
          2. It is not an uncommon error. If it was they would not have put out a TSB.
          • Debs1964
            • Oct 2010
            • 1687
            I don't know if this will help, I've not come across it, but when anyone tells me of any strange issues they've had I write it down in a book, and one of my entries is...
            Japanese after BICU EPROM replacement, set SP5-807-001 to 2
            There are 10 types of people in this world, those who understand binary maths and those who don't
            • Gift
              • Mar 2011
              • 2455
              Usually I'd say marketing area/region isn't set right in SP - make shure to compare and adjust the values from the birth certificate - it might be the SP mentioned by Debs. Once you're at it: Please check if the serial number from the counter print matches to the MFP. Some SPs might be just possible to edit within factory SP (Yellow-1-4...).
              That bulletin is interesting but I'm not shure if your case is perhaps more related to what happened during the board replacement *cough* - won't hurt to check and adjust the SPs according to that bulletin though..
                • 37052
                Based on the bulletin and what Debs posted, I would say that someone may have bent a pin on the BICU EPROM under when installing it. Doesn't hurt to check.
                • FrohnB
                  • Jul 2017
                  • 1919
                  Check all your flat cables/ harnesses going between boards. Maybe got bumped out of position during transport.
                  Did you pull the EEPROM from the Old BICU and install it into the new BICU?
                  If you replaced BICU, and did indeed swap the EEPROM over, then that leaves you with the IOB, or Paper Transport IOB that could be the issue, or possibly a harness not plugged in, or a flat cable not completely seated.
                  Omertà
                  • luca72
                    • Oct 2017
                    • 1711
                    you put the nvram with zero count, without reloading the parameters of the birth certificate ?
                    • luca72
                      • Oct 2017
                      • 1711
                      you put the nvram zero count?
