Has anyone came across this? I have a customer who has this on their IM C3000. I've replaced the BICU and the BCU, but still getting it even after resetting the SC code. When I go into SP Mode, i can click on system but can enter any values. rfg083871.pdf
Sc 66x occurs - sp mode displayed in japanese
Re: Sc 66x occurs - sp mode displayed in japanese
Typically it seems to suggest replacing BICU / Imaging IOB / Paper transport IOB (in that order) -
You've got the bulletin, why don't you just do what is says? Or do you lack the service manual?Comment
All the PDF says is to refer to the manual, they could put out a PDF for every code there is and it could just say the same thing...refer to the service manual.Comment
- It tells you what is causing the error code.
- It is not an uncommon error. If it was they would not have put out a TSB.
I don't know if this will help, I've not come across it, but when anyone tells me of any strange issues they've had I write it down in a book, and one of my entries is...
Japanese after BICU EPROM replacement, set SP5-807-001 to 2There are 10 types of people in this world, those who understand binary maths and those who don'tComment
That bulletin is interesting but I'm not shure if your case is perhaps more related to what happened during the board replacement *cough* - won't hurt to check and adjust the SPs according to that bulletin though..Comment
Check all your flat cables/ harnesses going between boards. Maybe got bumped out of position during transport.
Did you pull the EEPROM from the Old BICU and install it into the new BICU?
If you replaced BICU, and did indeed swap the EEPROM over, then that leaves you with the IOB, or Paper Transport IOB that could be the issue, or possibly a harness not plugged in, or a flat cable not completely seated.OmertÃComment
you put the nvram with zero count, without reloading the parameters of the birth certificate ?"I'll be back"Comment
you put the nvram zero count?"I'll be back"Comment
