ricoh mp c3300 black no load
  • die
    • Dec 2024
    • 7
    ciao il Toner nero non viene visualizzato esce solo la ricarica degli altri 3 colori al nero esce "non rilevabile" . Qual'è il codice devo usare in code sp per riattivarlo?
    Hi, the black toner is not displayed, only the refill of the other 3 colors comes out, the black one comes out "not detectable". What is the code I need to use in code sp to reactivate it?
    thanks
  • die
    • Dec 2024
    • 7
    i see this
      • 8145
      Are these OEM Canon toners ?
        • 37495
        thanks
        i see this
        Might be a couple of things:
        1. Bad RFID chip on the K cartridge
        2. Bad RFID board
        3. RFID ON/OFF:K SP 5804 192 not set correctly
        4. RFID Communication ON - K SP 5804 196 is OFF
        5. Memory for the K cartridge is corrupted
        Check the K SP settings against the other 3 colors. They all should be the same. If not, you probably have corrupted memory. That is usually the result of a corrupted chip or an After Market cartridge. Try the following:
        1. Turn SP 5804-192 OFF
        2. Cycle power
        3. Install a new Genuine Ricoh cartridge
        4. Cycle power
        5. Turn SP 5804-192 ON
        6. Cycle power
        If that does not correct the problem, I hope you have the Birth Certificate for that machine, because you are going to have to Clear Engine Memory. If you do not have the Birth Certificate, print the Non-Default page SP 5990-006 before clearing memory and use it. SP 2101 values will need to be entered and then run forced line position.
        • luca72
          • Oct 2017
          • 1780
          thanks
          either the chip contacts are dirty, or it is broken (more likely)... nothing happens, when the toner runs out the machine will let you know, and you will change it normally....it happens
          "I'll be back"
          • anothertech
            • 1771
            Probably not Canon, this is a Ricoh machine.
              • 37495
              Check the value of SP 8-891-1, remaining current black toner. If it is a negative number or a 2's complement then you have corrupted memory. If memory clear does not correct it, then unless you can get a new BICU, you have a boat anchor.
