problem with ip
  • romario
    • Jun 2020
    • 192
    [Jamming] problem with ip
    Hello, I present that small problem in mp301, I configure the ip as it should but I do not connect to the pc, I print the machine's ip report and I get ip 0.0.0.0. I already erase memory, activate network port in sp, exchange network controller, format the hdd and follow the failure, here I attach testsSin título-1.jpg
    thanks
    • 37532
    Re: problem with ip
    I find it interesting that that the picture of the display where you claim to have entered the IP settings and the printout of the network settings are in 2 different languages. Are you sure that you clicked on the OK button to save what you entered?
    • KeviM
      • Oct 2019
      • 324
      Re: problem with ip
      Agreed with Slimslob on this. You have to save the ip address or the system will automatically go back to the previous settings.
      Bit of a common fault if you not familiar with the system.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Re: problem with ip
        Originally posted by romario
        Hello, I present that small problem in mp301, I configure the ip as it should but I do not connect to the pc, I print the machine's ip report and I get ip 0.0.0.0. I already erase memory, activate network port in sp, exchange network controller, format the hdd and follow the failure, here I attach tests[ATTACH=CONFIG]50545[/ATTACH]
        Machine doesn't come with a hdd
        Clear the printer & ncs app in service mode make sure ieee802 is inactive in user tools also once setting new ip address machine needs to be rebooted
        Regards Mark
        • tsbservice
          Field tech
          • 8020
          Re: problem with ip
          What happens when you turn on DHCP?
          Also make sure you've all and correct firmwares.
          • mikadonovan
            • May 2008
            • 2931
            Re: problem with ip
            Don't forget this part, or it will not hold.
            NEVER ASSUME ANYTHING
            • anothertech
              • 1771
              Re: problem with ip
              +1 on the firmware, double check the operation panel firmware, sometimes the wrong firmware gets in there, I 've seen it a few times, no idea how it happens.
              • copier tech
                • 8172
                Re: problem with ip
                No, there is no need to reboot a Ricoh after changing the IP address settings.
                • mikadonovan
                  • May 2008
                  • 2931
                  Re: problem with ip
                  I used to have a ton of old 2051's that required a reboot for it to even appear on the config page. However, I just tried it on a c307, and no reboot was required.
                    • 37532
                    Re: problem with ip
                    That depends upon the model. I don't know about current models but most of the older ones only sent out a DHCP request during power up so if the IP setting were changed to DHCP then you had to reboot.
                    • copier tech
                      • 8172
                      Re: problem with ip
                      Maybe on machines older than 10 years but the MP 301 you don't need to restart after changing network settings.
                      I also turn on SP5055 to display the IP address at the top of the screen I find it useful to have this enabled.
                      • mikadonovan
                        • May 2008
                        • 2931
                        Re: problem with ip
                        Just as MGA suggested, turn off 802.11 access in user tools. According to your picture of the config page, it is "on" I think.
                        User tools>system>interface> bottom of page 2.
                        • mga
                          Copier Technician
                          • Dec 2010
                          • 1393
                          Re: problem with ip
                          Wow you learn everyday for years I've always when changing ip address or from static I've always rebooted.
                          Regards Mark
