Hello, I present that small problem in mp301, I configure the ip as it should but I do not connect to the pc, I print the machine's ip report and I get ip 0.0.0.0. I already erase memory, activate network port in sp, exchange network controller, format the hdd and follow the failure, here I attach testsSin título-1.jpg
problem with ip
Re: problem with ip
I find it interesting that that the picture of the display where you claim to have entered the IP settings and the printout of the network settings are in 2 different languages. Are you sure that you clicked on the OK button to save what you entered? -
Re: problem with ip
Hello, I present that small problem in mp301, I configure the ip as it should but I do not connect to the pc, I print the machine's ip report and I get ip 0.0.0.0. I already erase memory, activate network port in sp, exchange network controller, format the hdd and follow the failure, here I attach tests[ATTACH=CONFIG]50545[/ATTACH]
Clear the printer & ncs app in service mode make sure ieee802 is inactive in user tools also once setting new ip address machine needs to be rebootedRegards Mark
https://copierservices.simdif.comComment
Re: problem with ip
Also make sure you've all and correct firmwares.A tree is known by its fruit, a man by his deeds. A good deed is never lost, he who sows courtesy, reaps friendship, and he who plants kindness gathers love.
Blessed are they who can laugh at themselves, for they shall never cease to be amused.Comment
​Comment
NEVER ASSUME ANYTHINGComment
Re: problem with ip
That depends upon the model. I don't know about current models but most of the older ones only sent out a DHCP request during power up so if the IP setting were changed to DHCP then you had to reboot.Comment
Re: problem with ip
I also turn on SP5055 to display the IP address at the top of the screen I find it useful to have this enabled.
​Comment
Re: problem with ip
Just as MGA suggested, turn off 802.11 access in user tools. According to your picture of the config page, it is "on" I think.
User tools>system>interface> bottom of page 2.NEVER ASSUME ANYTHINGComment
Regards Mark
