Im c3000 processing has failed addressbook
  • CopyBats
    • Aug 2011
    • 146
    Hi Everyone,
    I am running in to the following issue. There were some threads posted earlier regarding the same issue but I could not get a resolution through them.
    I have an IM C3000 Off Lease / Repo that is a very low count. Unable to access the address book from the operational panel. Same result when logged in as admin. I am however able to access the address book via WIM.
    Any assistance would be appreciated. Processing has failed is the message that shows up after a few seconds when I am trying to access the address book from the smart operational panel.
    Thanks In advance.
    If it works, don't touch it.
  • luca72
    • Oct 2017
    • 1778
    Try to update the firmware machine via sd, and also of the display panel (sop) directly via sd card, if not wort, try to put a fly hdd to test, if not wort, save the smc data on sd card with SP and test another imc series nvram, if wort, you can buy a new costous nvram (from these series, have only One chip...they have understood the game, and they want to eat too)
    N.b. Ricoh says on a rtb, of not reset sop panel for not take disfunction (not specified)
    "I'll be back"
      • 8144
      Since you have received this device off lease I guess you don't need to keep the address book ?
      If not then I would use special SP mode to reset the admin password & HDD back to default settings.
        • 37489
        Log in as supervisor and see if they have a separate User administrator set.
        • Saturn
          • Nov 2023
          • 171
          5-846-046
          I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
          • Leoculus
            • Jul 2024
            • 62
            Originally posted by CopyBats
            Hi Everyone,
            Thanks In advance.
            i have had this happen twice to me now both times after formatting hdd due to an SC related to the HDD. new hdd did not fix issue but a reflash of the firmware fixed the issue. the one was a used machine for a donation to a youth hockey club. firmwares and format had been done prior to installation but after restoring the address book from their old machine it came up with this. as i had already done firmwares i did not immediately try them. tried different hdd/address book initialize/memory clear and reload nv ram/sop factory reset. ended up aborting the swap and brought it back to the office. reflash of firmware at the office fixed the issue but we had replaced the hdd also for good measure.
            the 2nd machine was the same. new hdd and reflash the firmwares fixed the issue
            • CopyBats
              • Aug 2011
              • 146
              Thanks everyone for your input. Tried all suggestions earlier. Turned out to be Firmware Update SOP that fixed this issue along with HDD replaccement.
              On to the next one!
