hi,
i have a problem with an mp6503, error sc-440-01 only print and copy on A3
SC440-01 | D | Transfer output abnormal (voltage leak detected) |
When the transfer voltage was output, the feedback voltage remained higher than 4V for 60 ms. |
• Transfer current terminal, transfer power pack disconnected, damaged connector • Transfer power pack defective |
• Remove the transfer unit • Inspect the terminals at the front and rear • Replace transfer power pack |
