Ricoh mp c2011, op panel keys not working
  • Marwanalhajbi
    • Jul 2018
    • 72
    i have a sc 672-11, i tried firmware update no hope,
    any suggestion please?
  • anothertech
    • 1768
    Re: Ricoh mp c2011, op panel keys not working
    Disconnect the hard drive and try it, also if it has a fax board, disconnect that too. Reseat the RAM. Remove and reinstall the controller board. Reseat the connectors at the operation panel and at the IPU.
    Check AC power coming into the machine, how many volts, is it steady?
    • luca72
      • Oct 2017
      • 1774
      agree with what anothertech has suggested to you, I suggest you to "squeeze" lightly with pliers, on both ends, the connectors of that damn Chinese usb cable, which connects the controller to the panel, the connection, and the vibrations, generate a lot of problems, the 'I have always found a little "free" to move! ... if you can without disassembling half machine, change it
      "I'll be back"
      • Maged_elagamy
        • Mar 2021
        • 42
        [ATTACH=CONFIG]50803[/ATTACH]
        this damn cable cause so much troubles
        • copier tech
          • 8142
          We saw this code a lot when the METIS model was first released. Update ALL firmware not just the package as the power save rom is not included.
          SC 672-11 or 12.pdf
