Ricoh IM C300 SC672-02
  • gilbert
    • Oct 2017
    • 38
    [Error Code] Ricoh IM C300 SC672-02
    Hellow Techs
    Please assist me i have IMC 300 which is not initializing.
    only laser motors are running, it is coming ready but will not print
    or copy once i command it to do so.It keeps on showing ""PROCESSING"'PRINTING"' until
    Sc672-02 appears.I have tried another BICU and Controller board form another device
    but error keeps coming.
  • Gift
    • Mar 2011
    • 2459
    Re: Ricoh IM C300 SC672-02
    Try another OP panel
    • luca72
      • Oct 2017
      • 1778
      Originally posted by gilbert
      Hellow Techs
      try to update the firmware, and to tighten a little the USB connectors of any cable that connects the panel to the board
      "I'll be back"
      • gilbert
        • Oct 2017
        • 38
        [ATTACH=CONFIG]50818[/ATTACH]
        I have managed to update firmware and checked the usb cable,the error has
        changed to Sc670-02
        • TonerMunkeh
          Professional Moron
          • 3865
          Make sure the toners are seated properly, this latest incarnation of the Griffin is just as annoying as it's older siblings for this.
          Hit it.
          • luca72
            • Oct 2017
            • 1778
            changed to Sc670-02
            probably, you are near to the solution, check that there are no hidden / disconnected connectors of the boards left, that you have tried to replace previously (it happens), and if you have the possibility try a "flying" usb cable, the psu could also be involved, android panel, is up to date ? .... here also speaks of "VODKA", but at this time it doesn't seem the case ... LOL!
            SC670-02
            The engine is off when the machine starts (it is possible to restart the SC) (* See "When SC670 is displayed" below)
            Machine inactivity was detected after the ENGRDY signal was not confirmed.
            • CPU reset from watchdog timer
            • CPU reset by software
            • CPU reset from CPU exception management
            • Restore VODKA slave
            • CPU recovery due to hardware / noise failure
            • VODKA recovery due to hardware / noise failure
            The motor board was unexpectedly reset.
            Check if the SC error occurs by turning the machine off and on again at least 10 times. If the SC error occurs again, proceed as follows. Check if the SC error repeats by turning the machine off and on again after each stitch.
            1. Reconnect the BiCU (PCB1) and the controller board (PCB24).
            Error. To apply 見 出 し 1 to the text to be displayed here, use the tab
            Home..Error. To apply 見 出 し 1 to the text to be displayed here, use the
            Home tab.
            615
            No. Type Details (Symptom, Possible Causes, Troubleshooting Procedures)
            2. Replace the card in the following priority.
            1. BiCU (PCB1)
            2. PSU (PCB16)
            3. Controller board (PCB24)
            "I'll be back"
            • anothertech
              • 1769
              Look Man, we don't read Dutch here on this English board, and no I'm not translating it, maybe you could before you post it.
              • luca72
                • Oct 2017
                • 1778
                sorry! I messed with copy and paste
                "I'll be back"
                  • 37488
                  Google translate is extremely easy to use. This is actually an international site with international membership.
                  • anothertech
                    • 1769
                    If I was going to post something on a site that used another language, I'd translate what I wrote into that language before posting, that way I'm the only one that has to translate it, instead of every person that wants to read it. Common sense, English board, post in English.
                      • 37488
                      Not entirely true. Let's say there any other members who only speak the same language as the person who makes the post speaks. They then have to translate it back.
                      • dalewb74
                        • Feb 2018
                        • 1153
                        for 672-02
                        1. Reconnect the USB cable and harness. (Reconnect both the operation
                        panel end and the controller end.)
                        2. Replace the USB cable and harness.
                        3. Replace the controller board.
                        4. Replace the operation panel.
                        for 670-02
                        • CPU reset by watchdog timer
                        • CPU reset by CPU exception handling
                        • Slave VODKA reset
                        • CPU reset due to hardware malfunction/noise
                        • Slave VODKA reset due to hardware malfunction/noise
                        The engine board was reset at an unexpected time.
                        Check if the SC occurs by turning the main power OFF then ON at least 10
                        times. If the SC occurs again, do the following steps. Check if the SC reoccurs
                        by cycling the power after each step.
                        1. Reconnect the BiCU (PCB1) and Controller board (PCB24).
                        2. Replace the board in the following priority:
                        1. BiCU (PCB1)
                        2. PSU (PCB16)
                        • gilbert
                          • Oct 2017
                          • 38
                          thank you for your response.did have sc670-02 how was it resolved?
                          • TonerMunkeh
                            Professional Moron
                            • 3865
                            I had to change the toner hopper and the BRB board when a customer went round a hospital unit looking for a yellow toner, breaking 4 machines in the process.
                            Hit it.
                            • gilbert
                              • Oct 2017
                              • 38
                              Hellow Techs
                              Griffin is not a good device to work on, I touched some cables on BICU it came
                              to SC570-02 . Touched toner hoper the error disappeared. Machine is now initializing
                              giving a noise from drive and sc240-02 pops up. I have tried another BK/CY laser FROM A WORKING MACHINE
                              error still appears.
