Ricoh MP C2503 does not detect any toner
  • fran780
    • Nov 2017
    • 7
    [Dead] Ricoh MP C2503 does not detect any toner
    Hello, I have a Ricoh MP C2503 that has had its EEPROM and NVRAM changed and now it does not detect any toner cartridge, neither new nor old, could you help me? Thank you.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh MP C2503 does not detect any toner
    Why has it had the nvrams changed?
    Hit it.
    • fran780
      • Nov 2017
      • 7
      data error in nvram
      • GIUBOSS
        • 1437
        you should upload the data contained in the birth certificate and then firmware
        • fran780
          • Nov 2017
          • 7
          the nvram data could not be copied because there was an error in the data
          • GIUBOSS
            • 1437
            The machine is blocked with the screen to insert the toners? The errors are in the old nvram, you have to copy the data of the sheet on the new ones. Have you updated the firmware? Also performed a clear memory?
            OEM toners?
              • 37628
              Do you even know what that birth certificate is? It is a sheet of paper that has all the non default settings made at the factory. It is sent with every machine as each can be different. It should be kept with the machine.
                • 37628
                You should still be able to get into SP mode. Change SP 3100-001 to 1 which turns off toner end detection.
                • luca72
                  • Oct 2017
                  • 1792
                  master shot!
                  "I'll be back"
                  • Polarbear
                    • Feb 2012
                    • 1070
                    I am confused.
                    The device is not detecting toner at all. How is turning toner END detection helping?
                    Press the GREEN button!!
                    • luca72
                      • Oct 2017
                      • 1792
                      Originally posted by Polarbear
                      I am confused.
                      it is to skip the error and proceed with more in-depth tests
                      "I'll be back"
                      • 8T2
                        • Aug 2015
                        • 257
                        We are starting to run into this issue more and more lately. Check the contacts on the toner bottle chip. Don't know what exactly is going on and if it's related to COVID and chip shortages but loads of new genuine sealed toners either have a new style blue chip as opposed to the regular green chip or a green chip that seems to be recycled because you can clearly see it's not new and the chip contacts are contaminated
                        Sent from my SM-A305F using Tapatalk
