IM C3010 ; Toner from an independent supplier
  • HBE
    • Sep 2018
    • 2
    How can I switch off this message? No original Ricoh toner is used
    • 37491
    You can turn OFF the RFID detection since the RFID chip on the bottle does not read properly with cheap after market toner bottles
    • HBE
      • Sep 2018
      • 2
      Which SP code is required for this?
      • Larhal
        • 571
        This is NOT possible to switch off.
        Larhal
        If all else fails read the Service Manual!
        If that fails, meet me at the pub and we will discuss it.
        • anothertech
          • 1769
          Try this,
          1. Set SP5051 to 1.
          2. Power copier off then back on.
          3. Set SP5051 to 0.
          4. Power copier off then back on.
