Reset drum IM C530
  • pakobernal
    • May 2012
    • 46
    Reset drum IM C530
    Good morning, greetings from Spain, a question, does anyone know how to reset the pcu counter in the im c530 model?
    Or do I necessarily have to change the unit?
  • copier tech
    • 8101
    Yes you can reset the PCDU counters, no need to replace if the quality is still good.
    Ricoh IM C530 Service Manual.pdf
    • pakobernal
      • May 2012
      • 46
      [ATTACH]n1600813[/ATTACH]
      I can't find it. I only can reset itb, paper transfer roller, fuser.... but pcu can't reset.
      • copier tech
        • 8101
        What about SP7-621-002 ?
        • pakobernal
          • May 2012
          • 46
          In 7621-002 I can see the counter, I cannot reset it
          • GIUBOSS
            • 1382
            If you really have to do it then try increasing the pages for the PCU PM replacement
            • anothertech
              • 1756
              Try resetting it in Special service mode, or Factory mode
                • 36807
                Try using SP7-622-02.SP7-621 is counter display, 622 is reset. As I do not have the manual for the IM C530, but that is what they were prior to the IM models.
                • copier tech
                  • 8101
                  I uploaded the manual in my previous post.
                  • pakobernal
                    • May 2012
                    • 46
                    I have tried and it doesn't work either.
                    • pakobernal
                      • May 2012
                      • 46
                      I can't find where increase it.
                      • pakobernal
                        • May 2012
                        • 46
                        In Im it works, but in Imc530 it does not work
                        • copier tech
                          • 8101
                          Did you find a way to reset this drum in the end ?
