SOP IM 430F
  • rmnvb
    • May 2021
    • 1
    SOP IM 430F
    Hi, i have a ricoh im 430f with smart operation panel.
    I have a problem that in normal mode it takes about 10 minutes with the black screen and the blue led on, only then it shows the blue screen and loads the applications (it also happens a lot in quick mode), the machine's engine works perfectly , only the panel is having problems.
    Has anyone ever experienced this?
    I've already tried to do the data and cache reset in recovery mode but without success.
    • 37400
    Re: SOP IM 430F
    Sounds like JAVA might be enabled. If it is, the engine does not finish startup and hand control to the SOP until JAVA finishes initializing. It has always been a problem with JAVA.
    • anothertech
      • 1762
      Re: SOP IM 430F
      Turn off Java if you are not using it. SP5730 set from 1 to 0
      • CopyBats
        • Aug 2011
        • 137
        Re: SOP IM 430F
        After disabling java, go to screen features and select function priority as copier ( not home or blank)
        If it works, don't touch it.
          • 37400
          Re: SOP IM 430F
          Unless the IM 403F is used primarily for scanning or Fax, then select the primary use function.
          • TonerMunkeh
            Professional Moron
            • 3865
            Re: SOP IM 430F
            Just factory reset the panel then reload the apps, if it keeps doing it then replace the main board.
            Hit it.
            • luca72
              • Oct 2017
              • 1752
              Re: SOP IM 430F
              as they all said disable java, either from user tools or from sp, as regards the start from off, also look in screen features, [panel start mode] that "quick" is set, and not "normal" (which I prefer ) .... personally I would also do a nice fw update of the android panel ... which is always good
              "I'll be back"
              • mikadonovan
                • May 2008
                • 2931
                Re: SOP IM 430F
                You might also want to look at TSB-093a. It covers faults on the Cheetah G2 SOP.
                NEVER ASSUME ANYTHING
                • anothertech
                  • 1762
                  Re: SOP IM 430F
                  How do I find that TSB? I do have access to the Ricoh TSRC
                  • mikadonovan
                    • May 2008
                    • 2931
                    Re: SOP IM 430F
                    In this thread.
                    https://www.copytechnet.com/forums/r...tml?highlight=
                    • copier tech
                      • 8131
                      Re: SOP IM 430F
                      Update the firmware this was/is a known issue.
