mp 2852 show functional problem need to restart before can be use。
When you get into SP mode, go to SP5-875-001 and change it to 1. After doing so that Functional Problem will no longer be shown. Instead the actual SC will be displayed and you can trouble shoot that.
could be various factor, check eventualy sc stored in memory, but could be for example, bad pcdu conctact, grounded charge roller, bad transfer roller or out of side, and the bad hdd
"loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
