Re: MP 6000 SC672
i think, are you going close, the power supply you have to try another one, or check the outputs (see P2P), last month, I got a mp4002, which was giving RDF jam, after having replaced practically everything (in the laboratory) at the end it was the PSU ... just to give an example of weird PSU jokes
it could be that the some "display" electronic part is not powered, or not enough(?)
however statistically I see here, that you change a little more IPU than PSU, but this only at the level of numbers ... since there is also that in the connection path
