Scanning with MP C306
  • lurker1652
    • Mar 2021
    • 58
    #16
    Re: Scanning with MP C306
    On the computer make sure that in the Advanced TCP/IP Settings on the WINS tab that the NetBIOS setting is either Default or Enable NetBIOS over TCP/IP. Name resolution is often through NetBIOS.
    The receiving end is a Linux based NAS. I can properly access the share with the given credentials using Windows 10 & Windows 11 clients, my understanding is NetBios is not enabled by default anymore. The MFP wouldn't be able to reach the share with DNS resolution?.
      • 37491
      #17
      Depending on the exact version of the NAS, it might nor work with MFP scan to folder. Every time I have had problems with scan to NAS it turned that the IT had installed the lowest priced model that gave the size the customer needed. Checking the manufacturer's website I found that it only worked with Windows PCs and then only using their software driver. They had 2 other models of the same size. The middle priced one didn't require the driver and the expensive one worked with scanners.
      • lurker1652
        • Mar 2021
        • 58
        #18
        It's a Linux machine running Samba, no non-standard clients/software are used.
          • 37491
          #19
          Is it or is it not a NAS like you said earlier? And have you checked with the manufacturer as to whether that model supports scanners?
          • lurker1652
            • Mar 2021
            • 58
            #20
            Checking with the admin, it's a software appliance: unRAID 6.10.
            I'm not aware of any standard "Scanner support feature" I could ask for. The thing is the MFP doesn't even initiate connection that they can debug.
            • dalewb74
              • Feb 2018
              • 1153
              #21
              Originally posted by Gift
              That one is new to me, gotta check it out if it's idiot-proof enough for recommending to end unsers lol
              i have used it. i wouldn't consider it user friendly for customers... if you have setup scanning before it is fairly straight forward. just to much going on, in my book, for a customer to setup. IT dept yes, customers no.
              and that's on windows. any other OS, i have no idea how well it works.
                • 37491
                #22
                I'm not aware of any standard "Scanner support feature" I could ask for. The thing is the MFP doesn't event initiate connection that they can debug.
                According to documentation available online simply by searching unRAID 6.10, for all new installations SMBv1 is disabled by default. In addition release rc2, September 2021, Samba version 4.15 SMB3 multi-channel is no longer marked "experimental", however is disabled by default. This may be enabled on the Settings/SMB Settings page. Some users have reported issues with SMB3 multi-channel in conjunction with certain network bond configurations. Has anyone gone into the SMB settings to see if SMB2 or SMB3 is enabled? That is assuming that the firmware for supporting SMBv2/3 is available for the C306, has been installed and is properly configured? If SMBv2/3 is not available on your C306 you will have to enable SMBv1.
                Now go do some homework.
                • lurker1652
                  • Mar 2021
                  • 58
                  #23
                  Hmm, I wonder what have you seen related to multi-channel & this behaviour. MC is not in use, since there's no multihomming here or the need to surpass 1Gbps.
                  Per Scanning with MP C306, it seems the firmware is new enough and properly configured. The culprit as stated, is that the client (MFP) is not able to initiate communication, there's no authentication attempt that can be directed to the authentication protocol differences.
                    • 37491
                    #24
                    Sounds like SMBv1/2/3 are all disabled on the NAS. At least one of them has to be enabled in order for scan to folder(SMB) to initiate communication.
                    • lurker1652
                      • Mar 2021
                      • 58
                      #25
                      Share is accesible from Windows clients, some SMB version must be enabled
                      Will try with firmware upgrade on the MP side.
                        • 37491
                        #26
                        SMB is not necessary for Windows to access a shared resource. SMB is Microsoft's implication of Samba added to allow access and share with to UNIX based system shares.
                        • rthonpm
                          • Aug 2007
                          • 2854
                          #27
                          Looking at your logs, the MFP is trying to connect on port 139, which is the old SMBv1 port of SMB over WINS. You may need to get the copier set to either use SMB 2 or higher which will also change the SMB port to 445 (SMB over DNS). My guess would be that SMB1 is disabled on the NAS, so when the MFP tries to negotiate a connection, there's nothing open for it to connect to.
                          DON'T go the route of trying to enable NetBIOS or anything like that: WINS is a dead protocol and many networks are disabling NetBIOS entirely. Don't go the route of enabling SMB1 on the NAS: that's even worse. Let these old protocols die in peace.
                          • lurker1652
                            • Mar 2021
                            • 58
                            #28
                            Could it be a failover?, like a second attempt?
                            #[smb client(3542)]22/06/05 22:06:08 SMBC: Failed to connect. timeout. (03201) ERR:
                            #[smb client(3542)]22/06/05 22:06:08 SMBC: Failed to connect 2nd port, 139. ERR:
                            From the config, it could be the case:
                            RICOH MP C306Z
                            Network Control Service Ver. 15.34.1
                            Copyright (C) 1994-2020 Ricoh Co.,Ltd. All rights reserved.
                            msh> smb
                            Workgroup Name : LAN
                            Computer Name : PRINTER01
                            Comment :
                            Notification : Off
                            Protocol : IPv4
                            Client Port : 445
                            Client Auth Level : 2 (NTLMv2->NTLM/LM)
                            Client WSD Browse : Off
                            Client Write Mode : Async
                            Client Timeout : 20
                            Client v3 : on
                            Some of the forum posts state using "1", others "2". Will try with "1" this afternoon.
                              • 37491
                              #29
                              RICOH MP C306Z
                              msh> smb
                              Comment :
                              Notification : Off
                              Protocol : IPv4
                              Client Port : 445
                              Client Timeout : 20
                              Client v3 : on
                              I might be wrong but I believe that Client v3 : on refers to SMBv3. If that is the case then SMBv3 is enabled on the C306. If so then it is either disabled on the NAS or blocked by the network.
                              • rthonpm
                                • Aug 2007
                                • 2854
                                #30
                                Is this a Workgroup environment, or Active Directory?
                                If Workgroup: is the Workgroup name identical between the copier and the NAS? Does the local account exist on both systems with the proper permissions?
                                If AD environment, is the NAS a member computer? Does the username for authentication have the domain as part of the user name: domain\user?
                                In either case, does the user have Modify permissions if you navigate to the share from a Windows machine and look at the Properties?
                                This sounds like more of an UnRAID issue than and MFP issue. The NAS is the more likely target for where the issue lies. Samba can be incredibly easy to configure, or an absolute nightmare.
