Scanning with MP C306
    • 37491
    #31
    Re: Scanning with MP C306
    Originally posted by rthonpm
    Is this a Workgroup environment, or Active Directory?
    If Workgroup: is the Workgroup name identical between the copier and the NAS? Does the local account exist on both systems with the proper permissions?
    If AD environment, is the NAS a member computer? Does the username for authentication have the domain as part of the user name: domain\user?
    In either case, does the user have Modify permissions if you navigate to the share from a Windows machine and look at the Properties?
    This sounds like more of an UnRAID issue than and MFP issue. The NAS is the more likely target for where the issue lies. Samba can be incredibly easy to configure, or an absolute nightmare.
    Damn, that got by me.
    In post #15 he indicated
    RICOH MP C306Z
    Network Control Service Ver. 15.34.1
    Copyright (C) 1994-2020 Ricoh Co.,Ltd. All rights reserved.
    msh> smb
    Workgroup Name : LAN
    but farther down in the same post
    msh> dhcp
    DHCP Configuration:
    Ethernet(ether):
    DHCP: On
    inet 10.2.0.53 netmask 255.255.255.0 broadcast 10.2.0.255
    WINS
    primary server 0.0.0.0 secondary server 0.0.0.0
    hostname printer01 ScopeID
    DNS Domain
    Selection : DHCP
    Domain Name : lan
    So it could be a domain and he needs to specify lan as the domain name in the C306 network settings.
    • lurker1652
      • Mar 2021
      • 58
      #32
      Thanks for commenting, Workgroup. Manually tried to copy files to/from the NAS using the copier user/password without issues.
      • lurker1652
        • Mar 2021
        • 58
        #33
        That "domain name" stance is for DNS client configuration, for when a short name (non FQDN) is used, the client library should append that domain to the short host. Either way, I setup the SMB client to use a FQDN (printer01.lan)
        • lurker1652
          • Mar 2021
          • 58
          #34
          What are your firmware versions?
          Most likely you are scanning via SMB v1.0 which as we know was/is a security risk & was blocked by MS with an update.
          Firmware:
          Module Name Version Part Number
          System/Copy 1.29 D1965401G
          Network Support 15.36 D1965792T
          Fax 10.00.00 D1965784L
          RemoteFax 05.00.00 D1965785F
          Scanner 01.24 D1965787R
          Web Support 1.17 D1965788Q
          Web Uapl 1.04 D1965789D
          animation 2.08 D1965790J
          NetworkDocBox 1.07 D1965793J
          Printer 1.16 D1965794T
          RPCS 3.18.13 D2145795C
          Font EXP 1.00 D1475581
          PCL 1.08 D2145796H
          PCL Font 1.14 M1095273
          PS3 1.00 D2145797A
          PDF 1.02 D2145798B
          PS3 Font 1.11 D6415763A
          Java VM v12 std 12.36.00 D2145799G
          Data Erase Onb 1.00 D2025556
          GWFCU3.8-9(WW) 06.00.00 D2145786H
          PowerSaving Sys F.26 D1965782A
          NAND FLASH O0312E -------
          Engine 1.13:03 D1965775J
          OpePanel -------- --------
          Applications:
          Application Name Version Part Number (or Product ID) Status
          M2a_System 1.27.2 D2411425F -
          M2a_BLEPlugin 2.12.00 D2411466 Not activated
          M2a_BluetoothSe 1.02 D2411465C Not activated
          M2a_cspf 2.02.00 D1961430B Not activated
          M2a_HelpService 1.00 D2411471 Not activated
          M2a_ICCdDisptch 2.12.04 D2411450A Not activated
          M2a_IDCardCopy 1.01 D1961447A Not activated
          M2a_iWnn 2.3.3 D1961403 Not activated
          M2a_iWnn_Hang 1.0.0 D1961406 Not activated
          M2a_iWnn_Hans 1.0.0 D1961404 Not activated
          M2a_iWnn_Hant 1.0.0 D1961405 Not activated
          M2a_LegacyUI 1.21 D2411427Y Not activated
          M2a_NFCPlugin 2.12.00 D2411452 Not activated
          M2a_ProgramInfo 1.18 D2411438D Not activated
          M2a_QRCode_SDC 2.1.2 D2411453F Not activated
          M2a_QuickCdAuth 2.12.04 D2411468A Not activated
          M2a_ScanToME 1.02 D1961412B Not activated
          M2a_ScnFldrHlpr 1.1.2 D1961448B Not activated
          M2a_SimpleCopy 1.20 D2411443S Not activated
          M2a_SimpleFAX 1.15 D2411445Q Not activated
          M2a_SimpleScan 1.15 D2411444R Not activated
          M2a_USBCdPlugin 2.12.00 D2411459 Not activated
          M2a_WEcoInfo 1.06 D2411437F Not activated
          M2a_WFaxInfo 1.03 D2411435E Not activated
          M2a_WLanguage 1.09 D2411431J Not activated
          M2a_WStopKey 1.01 D2411436B Not activated
          M2a_WTonner 1.05 D2411434G Not activated
          M2a_zoo 1.05.02 D2411467K Not activated
          Back
            • 37491
            #35
            I take this to mean you copied them from a PC to the NAS.
            Have you gone into the administrative setting on the NAS and checked whether SAMBA is enabled? If it is not, scan to SMB will not work regardless of the version of SMB supported by the C306. SMB is Microsoft's implementation of SAMBA. Linux and Unix based systems need SAMBA enabled in order for a MFP to scan to them.
            • lurker1652
              • Mar 2021
              • 58
              #36
              Correct, tested with Windows & Linux clients. Sure I did, otherwise the PCs can't access the share, it's the same protocol. There's not a "PC one" and a "MFP one".
                • 37491
                #37
                You are half correct, there is not a PC one.
                Also why does the documentation for the NAS have specific instructions for enabling SAMBA? Why did some versions of OS X have Apples version of SAMBAS removed and yet were still able to share folders/files with other computers? Now go to the NAS support website, download the documentation and read it. Or you can read it online like I did.
                • lurker1652
                  • Mar 2021
                  • 58
                  #38
                  I have disabled "NetBIOS over TCP/IPv4" in "Security --> Network Security", and I still see a Netbios exchange on the wire (query + response) :/
                  Afterwards, no other communication attempt is made.
