Scanning with MP C306
  • lurker1652
    • Mar 2021
    • 58
    I'm trying to scan to a CIFS share and for the life of me I cannot get it to work.
    The firmware is recent enough to support current versions of the protocol.
    Printing via network works fine, copying locally works fine too. Is the scan to share that's not.
    Any hints about how to troubleshoot this?
    • 30550
    Re: Scanning with MP C306
    Shared folder
    user name
    password
    are you using host name or ipaddress?
    • lurker1652
      • Mar 2021
      • 58
      Shared folder
      user name
      password
      Tried with both, it fails very quickly (would expect a connection timeout or something like that.)
      By the way, I only have an ethernet connection running to the machine. Would the touch panel scan app be able to use it?
        • 37628
        Why do you want to scan to a CIFS destination. According to TechTarget the CIFS protocol is obsolete. https://searchstorage.techtarget.com...le-System-CIFS
        There is also the possible problem that the MP C306 might not support the CIFS (Common Interface File System) protocol. Internet scanning might require the installation of Ricoh Integrated Cloud Environment (ICE). Or the use of some other cloud file system that allows installing as a local drive on a computer such as Google drive.
        • anothertech
          • 1771
          Does scan to folder with SMB work?
          • rthonpm
            • Aug 2007
            • 2860
            Technically, CIFS and SMB are the same protocol, though CIFS is now generally as referring to SMB1 or early versions of Samba. Every now and then you'll still hear someone refer to SMB as CIFS, which may be the case here.
            Double check the permissions on your shared folder, as well as the user account: permissions for NTFS need to be at least read/write to scan to a folder, and the MFP needs to be using local computer or domain credentials to connect to the folder: you can't use a Microsoft account as the user. If you're using any other OS beyond Windows then you may need to adjust a few other things in your config files.
            • sandmanmac
              • 3990
              Assuming he is correct about the F/W levels being recent enough to be compatible with latest version of Windows, then perhaps try using the scan to folder configuration tool to help you out:
              Scan to Folder Configuration Tool Downloads | Ricoh Global
              • Gift
                • Mar 2011
                • 2459
                That one is new to me, gotta check it out if it's idiot-proof enough for recommending to end unsers lol
                • copier tech
                  • 8220
                  What are your firmware versions?
                  Most likely you are scanning via SMB v1.0 which as we know was/is a security risk & was blocked by MS with an update.
                  • twalker
                    • Aug 2017
                    • 7
                    I would have to agree with Copier Tech, the firmware probably needs to be updated. Even if you think that it is recent enough, update it anyway. Another thing, make sure that the shared folder is set up properly. See if you can access that shared folder from another computer on their network using the same credentials as you are using on the copier. Try using their domain name as part of the username: domain\username. Also try using the IP address on the PC that is hosting the shared folder instead of using the host name: \\192.168.1.24\scans
                      • 37628
                      IMHO it is more a tool for help the tech. I would not trust it in the hands of the typical end user. Maybe their IT department but I have seen a few idiots there as well.
                      • tsbservice
                        Field tech
                        • 8064
                        I have batch script doing this thanks to member here. And I heard that Kyo and Ricoh have a tool for that purpose. Brother has built it in full driver package which is pretty cool if it works which is the case most of the times In any way it's good for techs to understand the process whether tools work or not.
                        • UNICORNico
                          • May 2018
                          • 308
                          It has been very:
                          Copy technician - 1 VS Computer Technician - 0
                          hahaha xD
                          "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
                          • lurker1652
                            • Mar 2021
                            • 58
                            MY apologies for the delay. It's not working up to this date, firmware seems to be new enough.
                            It seems name resolution is broken.
                            RICOH MP C306Z
                            Network Control Service Ver. 15.34.1
                            Copyright (C) 1994-2020 Ricoh Co.,Ltd. All rights reserved.
                            msh> smb
                            Workgroup Name : LAN
                            Computer Name : PRINTER01
                            Comment :
                            Notification : Off
                            Protocol : IPv4
                            Client Port : 445
                            Client Auth Level : 2 (NTLMv2->NTLM/LM)
                            Client WSD Browse : Off
                            Client Write Mode : Async
                            Client Timeout : 20
                            Client v3 : on
                            msh> syslog
                            #[ncsd(118)]22/06/05 21:39:05 *** Reboot completed! *** INFO:
                            #[rhppd(5726)]22/06/05 21:39:05 rhppd start. INFO:
                            #[nbtd(5745)]22/06/05 21:39:06 nbtd start. INFO:
                            #[smbserver(6080)]22/06/05 21:39:07 smbd start. (NetBIOS) INFO:
                            #[smbserver(6080)]22/06/05 21:39:07 Start smbd direct print mode (NetBIOS) INFO:
                            #[snmpd(216)]22/06/05 21:39:10 Snmp over IPv6 is ready. INFO:
                            #[wsprnd(5801)]22/06/05 21:39:11 WSD (Printer) started. INFO:
                            #[wsdevd(5400)]22/06/05 21:39:13 WSD (Device) started. INFO:
                            #[wsscnd(5872)]22/06/05 21:39:18 WSD (Scanner) started. INFO:
                            #[nbtd(5745)]22/06/05 21:39:18 Name registration success. Broadcast name=PRINTER01 (Ethernet) INFO:
                            #[nbtd(5745)]22/06/05 21:39:19 Name registration success. Broadcast name=LAN (Ethernet) INFO:
                            #[dhcp6cd(5483)]22/06/05 21:41:27 DHCPv6 server not found ERR:
                            #[dhcp6cd(5483)]22/06/05 21:48:30 DHCPv6 server not found ERR:
                            #[smb client(3414)]22/06/05 21:51:04 SMBC: Failed to connect. timeout. (03201) ERR:
                            #[smb client(3414)]22/06/05 21:51:04 SMBC: Failed to connect 2nd port, 139. ERR:
                            #[dhcp6cd(5483)]22/06/05 21:55:50 DHCPv6 server not found ERR:
                            #[smb client(6928)]22/06/05 21:56:05 SMBC: Failed to connect. timeout. (03201) ERR:
                            #[smb client(6928)]22/06/05 21:56:05 SMBC: Failed to connect 2nd port, 139. ERR:
                            #[smb client(5849)]22/06/05 22:01:07 SMBC: Failed to connect. timeout. (03201) ERR:
                            #[smb client(5849)]22/06/05 22:01:07 SMBC: Failed to connect 2nd port, 139. ERR:
                            #[dhcp6cd(5483)]22/06/05 22:03:08 DHCPv6 server not found ERR:
                            #[smb client(3542)]22/06/05 22:06:08 SMBC: Failed to connect. timeout. (03201) ERR:
                            #[smb client(3542)]22/06/05 22:06:08 SMBC: Failed to connect 2nd port, 139. ERR:
                            msh> dhcp
                            DHCP Configuration:
                            Ethernet(ether):
                            DHCP: On
                            inet 10.2.0.53 netmask 255.255.255.0 broadcast 10.2.0.255
                            WINS
                            primary server 0.0.0.0 secondary server 0.0.0.0
                            hostname printer01 ScopeID
                            DNS Domain
                            Selection : DHCP
                            Domain Name : lan
                            Common
                            DNS Server
                            Selection : DHCP
                            primary : 10.2.0.2
                            secondary : 0.0.0.0
                            option204 : Off
                            msh> dns resolvresolv.conf /udom/resolv.conf
                            nameserver 10.2.0.2
                            search lan
                            msh> winsWINS Configuration:
                            Ethernet(ether):
                            WINS: Off
                            ScopeID
                            Current configuration:
                            I wonder if NETBIOS has something to do, I can't find an explicit configuration to disable it and force DNS.
                              • 37628
                              On the computer make sure that in the Advanced TCP/IP Settings on the WINS tab that the NetBIOS setting is either Default or Enable NetBIOS over TCP/IP. Name resolution is often through NetBIOS.
