ricoh mp 2501sp clear print
  • Mediaservice srl
    • Feb 2025
    • 11
    clear print by disconnecting the bias connector perfect copy, tested ht board working, tested development group working
  • davel
    • Oct 2011
    • 1076
    Please elaborate
    • Mediaservice srl
      • Feb 2025
      • 11
      1) clear print
      2) I unplug the cable
      3) perfect print
      4)installed new card same problem
      • davel
        • Oct 2011
        • 1076
        Wild guess, replace the PCU. What are the PM counts.
        • Mediaservice srl
          • Feb 2025
          • 11
          Tested pcu (photoconductor unit) on another copier pcu works
          • luca72
            • Oct 2017
            • 1677
            Originally posted by Mediaservice srl
            1) clear print
            3) perfect print
            mumble...mumble....ok, board ok, pcdu ok, on another machine..
            maybe some contact sheet between pcdu and wiring, on the back behind the board
            • luca72
              • Oct 2017
              • 1677
              I forgot.....try stopping the machine during printing, and check the image on the drum as it is, if it is ok, some spring or part from the transfer roller may have come off.
                • 36796
                1) clear print
                3) perfect print
                How about a full page scan of the problem? You have a full page scanner right in front of you, why the hell did you have to take useless cell phone pictures?
                • Mediaservice srl
                  • Feb 2025
                  • 11
                  the image of the drum is faded
                  • luca72
                    • Oct 2017
                    • 1677
                    if the laserbox its cleaned.....then investigate pcdu>mc contact and hvt wiring
                    • Luism
                      • Dec 2024
                      • 17
                      Hello, I will try to change the End block polarization and cylinder load sops
                      • Luism
                        • Dec 2024
                        • 17
                        You must have a current leak in the terminals of the machine
                          • 36796
                          Common cause is a dirty laser shield glass.
                          • Mediaservice srl
                            • Feb 2025
                            • 11
                            no
                            • KeviM
                              • Oct 2019
                              • 324
                              It would seem like you have a high voltage charge leak occurring between the high voltage board and the PCU or the transfer and separation unit.
                              If you have changed and tested the PCU and the high voltage board then I would recommend getting some sort of rubberizing paint or plastic paint and neatly painting the plastic blocks that the metal charge wires travel through. Also try changing the transfer and separation unit.
                              Good luck friend
