Savin 7502 Error SC142-00
  • Porhuor
    • Feb 2023
    • 30
    [Error Code] Savin 7502 Error SC142-00
    I got a problem with my photocopy Savin 7502 after not using about 5 days , when turn on machine it showed that SC-142
    1. I try to clean exposure lamp, glass
    2. change expousure lamp
    3. change borad as in picture
    4. change len
    all of that can not solved the problem do everyone has an experiences about it plese share to me
    thank in advanced 🙏
    This gallery has 2 photos.
    • 8101
    • Code: 142
    • Description:White level detection error The white level cannot be adjusted to the second target level within the target during auto gain control.
    • Causes:• Dirty exposure lamp or optics section • SBU board defective • SIOB defective • IPU board defective • BCU board defective • Harnesses are disconnected. • Exposure lamp defective • Lamp stabilizer defective • Scanner motor defective
    • Update the firmware
    • Porhuor
      • Feb 2023
      • 30
      • Code: 142
      I changed boards and lamp but it can not
      only update the firmware?
      • Luism
        • Dec 2024
        • 17
        Hello. Under the exposure glass there is a white band, change it or change the glass for one from another machine
        • Porhuor
          • Feb 2023
          • 30
          Do mean this one ?
          • Luism
            • Dec 2024
            • 17
            Yes, correct, the bottom has a white band to establish the white pattern, if it is not white enough you can throw the code
            • Luism
              • Dec 2024
              • 17
              Does the scanner move correctly? If you place it to the right, look for the home position?
                • 36807
                Usually dust to toner has gotten under it.
                • Luism
                  • Dec 2024
                  • 17
                  First solve the white band to see if the problem is there, (you can put a strip of white paper to test) then see the developer to see if it spreads toner (how many copies does it have?)
                  • luca72
                    • Oct 2017
                    • 1677
                    4. change len
                    thank in advanced 🙏
                    I see you replaced the lamp, it lights up during the "hp check" cycle when you turn on the machine, if not, it could be the SBU
