MP C2004 not recognising toner
  • aAandy
    • Apr 2012
    • 370
    Hello everyone
    this machine shows no Y & M toner when toners not installed, but when toners are installed they are listed as "not detectable" - they are OEM toners, i cleaned and vacuumed the chips & the contacts inside the machine, no difference! i fitted a brand new M and still no change
    any suggestions please and thank you!
    • 37490
    SP3100 [Tonner End Detection: Set] may be the cause. Change from 0 Detect to 1 Not Detect and see what happens. FYI OEM does not mean Genuine Ricoh. For best results only use Genuine Ricoh. Third party chips can corrupt toner memory.
    • Luism
      • Dec 2024
      • 26
      It's correct, 100% agree
      • aAandy
        • Apr 2012
        • 370
        thanks Slim
        by OEM i meant genuine Ricoh (Original Engine Manufacturer) - will try SP3100 from 0 to 1
        much appreciated!
        • dalewb74
          • Feb 2018
          • 1153
          also i ran into this in the past. the ricoh box said it was the correct toner for that model. but wouldn't recognize it when installed. but just below where the toner was seated was a sticker telling the toner part #. which was different from what was listed on the ricoh box that stated it was for that model. when i ordered using the toner part # on sticker it worked.
          • aAandy
            • Apr 2012
            • 370
            made no difference!
            • aAandy
              • Apr 2012
              • 370
              the sticker was inside the machine just below where the toner goes in?
              • dalewb74
                • Feb 2018
                • 1153
                correct. i don't remember the model. but i believe that is the only ricoh that i have ever seen that has had the sticker.
                • aAandy
                  • Apr 2012
                  • 370
                  thanks, i'll check it
                  • Lions86
                    • May 2021
                    • 5
                    There is a toner helix block on the back of the place where the toner is installed. If there is a blockage in this section like the mixer or a fault in the part that makes the mixer, it gives a toner error when there is no toner flow. For your information
                    • levillageinformatique
                      • May 2025
                      • 18
                      have you update firmwares ? one firmware check the rfid one the toner bottle, if it's not french you have this message .
                      Have you changer or invert the ship, for exemple yellow and cyan to make a test ?
