MP 2004 EX - Abnormal paper exit noise
  • printertnc
    • Jun 2015
    • 68
    Good evening everyone.
    I have a 2004 mp with this strange defect.
    There is a strange noise coming from the paper exit.
    The machine has about 45,000 copies
    Ricoh Problem Mp 2004 - YouTube
    It is noticeable from the 30 second onwards. This kind of ticking
    What do you think about it?
    Thanks for your support
  • sandmanmac
    • 3979
    Re: MP 2004 EX - Abnormal paper exit noise
    Why are you focused on the finisher exit tray when the noise occurs well before it even starts moving .
    That noise is almost certainly coming from near the actual machine exit section -if there was not a bridge unit and finisher installed. Sounds like a fuser bearing.
    I've not worked on this particular unit, but heard similar noise on the 30ppm and up xx03 series
    Running outputs in SP mode for drum/ transfer, and fuser (with it removed). That should help isolate the issue.
    • Gift
      • Mar 2011
      • 2458
      If this is about the knocking sounds, that's probably a dry ball bearing contact surface (ball bearing->press roller shaft).
      • anothertech
        • 1762
        Run the fuser motor in I/O mode to help narrow it down.
        • mikadonovan
          • May 2008
          • 2931
          It does sound like a fuser bearing.
          NEVER ASSUME ANYTHING
          • TonerMunkeh
            Professional Moron
            • 3865
            Sounds like the fusing sleeve to me.
            Hit it.
            • anothertech
              • 1762
              Take the fuser apart, put high temperature grease on the inside and outside races of the pressure roller bearings.
              • MBZ6301
                • Aug 2016
                • 42
                I'd swap the gears as a set. Sometimes you can clean them up but if the bearings have been damaged it might last a year, month, etc
                Or find which one feels bad and get it swapped
                AB012116
                AB012120
                AB012119
                • luca72
                  • Oct 2017
                  • 1748
                  it does not seem to me a known noise of the paper output, it seems to me rather the fusing gears (already suggested above mbz6301) that are about to go, or at least the bearings that need a syringe of grease between the roller and the bearing - p.s. if you try the fuser output check, remove the waste toner box, so the lamps do not turn on, otherwise the sleeve could be damaged! ... but I think you can see it just with your eyes if you look at the gears
                  "I'll be back"
                  • UNICORNico
                    • May 2018
                    • 308
                    I agree with some of my colleagues. It is similar to the noise of bearings, when they are dry.
                    "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
                    • printertnc
                      • Jun 2015
                      • 68
                      good evening
                      I was able to trace the problem (Simulating the closed door and pressing the two side sensors)
                      As in the image below the problem is in this area.This anomalous noise comes from here.
                      I tried to give some "fat" in the part circled in red, but the problem persists.
                      inline — ImgBB
                      • sandmanmac
                        • 3979
                        good evening
                        inline — ImgBB
                        That "area" would be the Fuser unit that nearly EVERYONE has told you is the cause of the issue.
                        Remove it and service it -or call someone who can.
                        It's literally 2 screws to remove it and apparently you haven't even accomplished that in over a week
                        • printertnc
                          • Jun 2015
                          • 68
                          Good evening. I understand your disappointment but guys, I'm a novice technician, and this customer is very far from me.
                          I will proceed to remove the fuser, then I have to change the 3 gears right?
                          What is the cause of the problem? The printer is brand new.
                          Thanks for your patience and support
                            • 37376
                            What do you consider "vary far"? About half of my customers were at least an hours drive away, some as much as tow hours.
                            PS. I doubt if the MP C2004EX is "brand new" since it is a discontinued product replaced by the IM C2000 which has also been discontinued and replaced by the IM C2500.
                            • sandmanmac
                              • 3979
                              We can't go do the service call for you! . .....so much good advice already provided!
