M 2701 - Where to set SSL for the SMTP server?
  • mrwho
    Major Asshole!
    • 4299
    [Misc] M 2701 - Where to set SSL for the SMTP server?
    Good afternoon all.
    I can't find where to configure encryption for the SMTP server on this model. I can't believe it doesn't support SSL in a time when almost all servers require it.
    Anyone?
    Cheers.
    Mascan42
    Ibid
  • luca72
    • Oct 2017
    • 1781
    Re: M 2701 - Where to set SSL for the SMTP server?
    Originally posted by mrwho
    Good afternoon all.
    Anyone?
    Cheers.
    every time i hear ssl, smtp, scan to mail, i always get a headache
    "I'll be back"
      • 8164
      Good afternoon all.
      Anyone?
      Cheers.
      Same as with most models now, might just need a firmware update.
      • mrwho
        Major Asshole!
        • 4299
        You tell me....
        https://www.ricoh-chameleon.info/Xan...3dea9e6ca5.pdf
        Frimware is at the latest version.
        (I missed that word...)
        I thought "Maybe I just need to insert the correct port number (25 for plain, 465 or 587 for encrypted) and the machine assumes the correct action" and... no. Port 25 works fine, 465 and 587 does not.
        Mascan42
        Ibid
          • 37513
          Every time I see a post from mrwho, I get a headache.
          • mrwho
            Major Asshole!
            • 4299
            I like to share the pain...
            Mascan42
            Ibid
            • tsbservice
              Field tech
              • 8019
              Good afternoon all.
              Anyone?
              Cheers.
              I'm not sure but you may need firstly to create and install device certificate.
                • 37513
                Actually SSL/TLS/STARTLS for sending to an SMTP server require a current site certificate from a valid internet Certificate Authority.
                • mrwho
                  Major Asshole!
                  • 4299
                  That's odd, was never needed on any device so far (that I know of). Also, there's no mention whatsoever of SSL on the email screen... Will report to Ricoh, will let you know when I get an answer.
                  Cheers!
                  Mascan42
                  Ibid
