PRO1357 light prints
  • bojans
    • 1313
    #16
    Re: PRO1357 light prints
    Yes that motor. Not the one that drives the toner pump.
    • Keegan Chetty
      • May 2015
      • 113
      #17
      Bojans, Slim.. Thanks will try replacing that motor, fingers crossed.
      • KeviM
        • Oct 2019
        • 324
        #18
        There's been loads of issues with machines recently due to the return of load-shedding and and other electrical issues. Power surges, brown outs, etc..
        Hope you come right with the problem
        • Keegan Chetty
          • May 2015
          • 113
          #19
          Update : I've tried replacing the toner motor and the problem continues.
            • 37532
            #20
            Check the setting of SP 2208 Toner Supply Mode. If it is set to 1 Pixel Count Control that could be your problem. Pixel count can tend to slowly under tone as it does not use either of the sensors, TD or ID. It is intended for temporary use when one of the sensors is bad and you are waiting for a new one.
            • Keegan Chetty
              • May 2015
              • 113
              #21
              It is on 0 - sensor control, I did have it set to 1 a while ago for testing purposes but it made no difference.
              • mrwho
                Major Asshole!
                • 4299
                #22
                Is there any message of toner end? Also the id sensor under the drum might be failing - sorry, hadn't read the last post.
                Mascan42
                Ibid
                • Keegan Chetty
                  • May 2015
                  • 113
                  #23
                  No toner end picking up and I did replace the ID sensor as well. VSG and VSP are showing correct values
                  • mrwho
                    Major Asshole!
                    • 4299
                    #24
                    Try to split the developing unit and check if toner falls down from the toner hopper when you rotate the toner supply gear...
                    If it does, check the toner supply motor (not the pump one, the one that rotates the toner hopper gear that makes the toner drop from the toner hopper onto the developing unit)
                    Mascan42
                    Ibid
                    • Keegan Chetty
                      • May 2015
                      • 113
                      #25
                      I will split the units tomorrow and check that.. But I did already replace the dev unit with the toner hopper from a working machine for testing purposes and the motor that drives the hopper as well
                      • Codex
                        • May 2008
                        • 704
                        #26
                        If you do a forced toner supply,.. The copy becomes better?
                        Inviato dal mio SM-G935F utilizzando Tapatalk
                        Memento Audere Semper
                        • Keegan Chetty
                          • May 2015
                          • 113
                          #27
                          Yes it does, it works for like 200 copies then goes light again. When I replaced the ID sensor it made about 10k copies then got light again
                          • KeviM
                            • Oct 2019
                            • 324
                            #28
                            This is some stuff I would try. Not sure if it will work for you but it did work on a machine I working with recently.
                            SP 2209 - I set this to a low value. Something like 200 and let the client run the machine for about 2000 prints to see the outcome.
                            SP2210 - I set this to 5. I believe the default is 10. Again I made the client run the machine for about 2000 prints or more and monitored closely.
                            I had to be very careful it didn't over-tone,.. Which it did for 1 moment... I adjusted it again before it got bad
                            All the best
                            • Keegan Chetty
                              • May 2015
                              • 113
                              #29
                              All the best
                              Thank you I will try these and let you know, luckily it is not a client's machine but one of our own as we have a print bureau in house so I will monitor closely tomorrow
                              • KeviM
                                • Oct 2019
                                • 324
                                #30
                                Thats good. Gives you more freedom to work.
