PRO1357 light prints
    • 37533
    #31
    Re: PRO1357 light prints
    Originally posted by Keegan Chetty
    Yes it does, it works for like 200 copies then goes light again. When I replaced the ID sensor it made about 10k copies then got light again
    Worked for 10k after replacing the ID sensor? You might now have a dirty ID sensor. Clean it with a camera lens brush. Do not vacuum as that can cause static which will destroy the sensor.
    Are you getting a lot of toner scattering? You may be having problems with the development unit toner suction system. The hose from the development unit down to the suction pump might be clogged or otherwise restricted or the suction pump could be bad. Replace both with new, not ones taken from another machine.
    • Keegan Chetty
      • May 2015
      • 113
      #32
      I did replace the ID sensor with a new one, its all clean, no toner spillage anywhere. I also cleaned the pipe and there was hard toner in there but that did not resolve the issue, I did not replace the suction pump though, will order a new one and let you guys know the outcome.
      • Keegan Chetty
        • May 2015
        • 113
        #33
        Capture.JPG is this the suction pump you are talking about? B2343094
        • mrwho
          Major Asshole!
          • 4299
          #34
          I believe he means D0593261
          Mascan42
          Ibid
          • Keegan Chetty
            • May 2015
            • 113
            #35
            [ATTACH=CONFIG]52035[/ATTACH]
            That is a toner supply pump not the toner suction, however, I did replace the supply pump with a new one.
              • 37533
              #36
              [ATTACH=CONFIG]52034[/ATTACH] is this the suction pump you are talking about? B2343094
              YES.
              • mrwho
                Major Asshole!
                • 4299
                #37
                Sorry, my bad.
                I thought that might *not* be it because, in my experience, usually when that pump fails I get toner dusting and dirty prints.
                Have a nice weekend!
                Mascan42
                Ibid
                • Keegan Chetty
                  • May 2015
                  • 113
                  #38
                  YES.
                  Update: I have replaced the suction pump and 15k copies later still running perfectly. Thanks everyone!
