MP 9003 lite copies
  • Joe Foe from Buffalo
    • 399
    MP 9003 lite copies
    Looking for words of wisdom on cause. MP 9300 lite,grey copies, prints. Before I touched it has a history of same from previous techs. I replaced developer no luck. Unable to set td sensor. Click on this for details
  • Luism
    • Dec 2024
    • 27
    Hello, you're missing digits in the developer serial number (you can fill it with zeros), which is why the developer won't start.
    Regards
      • 37532
      If it was just copying I would say dirty optics. Since it is printing also, most likely a dirty or bad ID sensor. If by TD sensor you actually mean the ID sensor, SP 3001, then a dirty sensor will cause a reading considerably greater than 70. The dirtier the sensor, the higher the reading. The higher the reading, the lighter the print. If there is a lot of toner on the PCU frame the sensor is mounted on you may need to replace the cleaning brush. I have also seen the opening through the front of the PCU housing clog.
      • luca72
        • Oct 2017
        • 1784
        Regards
        yes, actually you can write whatever you want, I write some swear words....since nobody sees it
        strange, I see that the "check" sign at the bottom is red, and the front door is open
        "I'll be back"
        • Javad
          • Jun 2025
          • 6
          Hello, for sp2801, set all 7 digits to 1 and start. Check if the numbers for sp2201 are normal or not. If your income is weak, turn off sp3901.
