SC 672-00
  • tavorh
    • Sep 2016
    • 25
    SC 672-00
    Hi, I have a problem with mpc2004ex and mpc3004ex. On both devices there is sc-672-00 code. I changed control panel, usb cable and I also removed hdd but the problem is still there. Any solutions?
    • 8121
    Re: SC 672-00
    Try a firmware update if this won't start or fails replace the controller board.
      • 37062
      Re: SC 672-00
      Well since you have already replaced the Control Panel and the USB cable going to the control panel, that leaves the other end of the USB cable. Try replacing the controller.
      • luca72
        • Oct 2017
        • 1711
        Re: SC 672-00
        it can be easily the cheap usb cable , try to change or press with a little pliers the connector to improve the grip
        however if I remember correctly on that series there is a row of LEDs on the controller, which turn on and off, depending on their status, you can diagnose what the controller sees. there is a bulletin on this, for interpret the sequence, but now I'm home... maybe there is also on manual, but I saw it on a bulletin
