Hi friends, i have a in all the ricoh MPC machines when machine doing self checking after finish the check any one of the(mostly black colour) drum or charger roller or sometimes both getting spark or short. When i print the first copie after self checking the print comes with a line or dot dot line. If anybody knows what is cause of the problem and solution please let me know, i attached the sample of print and sparked drum and charger roller. Thank you.
Mpc3003 (all the ricoh models) drum and charger roller getting spark or short problem
Re: Mpc3003 (all the ricoh models) drum and charger roller getting spark or short pro
Pretty low counter, I guess these are the initial consumables from ~2014. It seems that a foreign particle wen't throught the print process - I've seen this every now and then.
I'd probably swap the dev+dum unit and vac out the toner path, cleaning unit etc.Comment
Hi friends, i have a in all the ricoh MPC machines when machine doing self checking after finish the check any one of the(mostly black colour) drum or charger roller or sometimes both getting spark or short. When i print the first copie after self checking the print comes with a line or dot dot line. If anybody knows what is cause of the problem and solution please let me know, i attached the sample of print and sparked drum and charger roller. Thank you."I'll be back"Comment
If the charge roller was arcing to the drum- You would be able to hear it
- It would arc once and then throw a Service Code and stop
I have seen a similar dot problem with B/W Type 1027 PCU when the charge roller.Comment
Hi sir thank you for your response. In my case there is no error code appearing.Comment
The two black lines, are they approx the drum circumference apart? I'd go with a new drum, cleaning blade and charge roller to start (vac out the drum unit and process area) and see from there.Comment
is it not that the customer has put stapled sheets without noticing it in the cassette? ... the area is usually that .... for the dots on the charge roller I don't know....there is nothing in the machine that has that circumference"I'll be back"Comment
Hi sir thank you for your response. No sir, It is a compact drum and charger roller my boss bought, i had changed 2 sets of drum and charger roller still coming same problem.Comment
Since you've already replaced the same parts twice, the time you've spent onsite and two sets of components has already eaten any cost savings.
Sent from my BlackBerry using TapatalkComment
No magic answer here.
From your pictures the drum looks damaged.
Not what us professionals would call 'spark or short'
But still I didn't know what is main cause of the problem. Any way thanks to all of you for response to my post and please keep supporting me.Comment
I dont know did you get answer but, before self check you can see 2 dots on A4, and after self check you can see lines. Your OPC is damaged and need replace.
The problem is that OPC is damaged by something. Screwdriver or similar. You will see 2 dot when electric charge is low and after self test, el charge is high so when ground from OPC touch paper or ITB, it make short cycle and line will appear. After some time, el charge will be lower and again you will see only 2 dots on A4.Comment
