MP C3003 Auto Color Calibration
  • aAandy
    • Apr 2012
    • 370
    hello everyone
    i am refurbing a machine for a client and upon attempting to perform Auto Color Calibration i get the following message
    "You do not have the privileges to use this function"
    i notice there is a login option when User Tools is entered, but there is no way to get the login info as the machine was bought used at auction
    is there any way to disable admin login in SP mode?
    thanks in advance
    Andy
  • 8T2
    • Aug 2015
    • 257
    Re: MP C3003 Auto Color Calibration
    I would check the admin settings in WIM and disable it from there. If I recall correctly it's Machine Admin that needs to be disabled
    Sent from my SM-A305F using Tapatalk
      • 37379
      Normal SP NO. You have to be logged in to either User Tools or WIM as the administrator. Try admin with no password, that is the default. If that doesn't work then try supervisor with no password. Supervisor can do one thing and one thing only, change the administrator credentials. If you know how to enter Factory SP then SP 5846-046 will reset the both to default, no password.
      • aAandy
        • Apr 2012
        • 370
        thanks for the response, i forgot to mention the machine is in a shed with no network
        • aAandy
          • Apr 2012
          • 370
          thanks for the response!
          i've not used factory SP on machines with the 806182 SP entry, is it the same as for the machines with 107 SP entry?
            • 37379
            Yes, Factory mode has not been change.
            • aAandy
              • Apr 2012
              • 370
              thank you Slim, much appreciated
              • luca72
                • Oct 2017
                • 1748
                hello everyone
                thanks in advance
                Andy
                as slimslob says, log in as supervisor, and expire all admin passwords
                "I'll be back"
                  • 8131
                  hello everyone
                  thanks in advance
                  Andy
                  Have you tried the default log in?
                  admin & password blank.
