ricoh mpc 6003
  • esvesdin
    • Mar 2022
    • 22
    ricoh mpc 6003
    hello everyone i have issue with magenda opc drum as you can see in the attached image , the drum is new as the cleaning blade , someone has encountered a similar problem
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: ricoh mpc 6003
    The magenta PCU requires replacing, not rebuilding. Black doesn't look too clever either.
    Hit it.
    • sandmanmac
      • 3985
      Re: ricoh mpc 6003
      Posts like this are so frustrating, you've obviously used inferior parts, and/or done poor job installing them.
      You have created this issue, so how can we be expected to figure out what you did wrong?
      • luca72
        • Oct 2017
        • 1791
        Re: ricoh mpc 6003
        You put the flea in my head....could it be the badly fitted charge roller (?)
        "I'll be back"
        • esvesdin
          • Mar 2022
          • 22
          Re: ricoh mpc 6003
          of course it is easier to replace a complete opc but it is much cheaper to change it separately
          greetings
          • Zaxxon
            • 608
            Re: ricoh mpc 6003
            +1
            Please start you post with brand, model, problem.
            • esvesdin
              • Mar 2022
              • 22
              Re: ricoh mpc 6003
              I did not mention that the problem occurred to me after 10,000 prints
              which means that the parts and installation are o.k.
              • copier tech
                • 8195
                Re: ricoh mpc 6003
                greetings
                I feel your pain the drums on the C3003 are super expensive. However you can fit the cheaper MP C3004 series black PCU as colour quite & saving & still using genuine parts.
                • esvesdin
                  • Mar 2022
                  • 22
                  Re: ricoh mpc 6003
                  i didn't change it i just cleaned it up but it seems to be good
                  greetings
                  • sandmanmac
                    • 3985
                    Re: ricoh mpc 6003
                    No...that actually means that the parts are probably $hit.
                    It might be "cheaper" to replace with generic Crap, but if you have to do it over and over, are you really winning?
                    Tear it apart and replace them again my friend - you'll be good to go for another 10K
                    • luca72
                      • Oct 2017
                      • 1791
                      Re: ricoh mpc 6003
                      greetings
                      for me, the problem is there, try to exchange the charge assembly with that of the yellow
                      Maybe, you have cleaned too strong(?)
                      "I'll be back"
                      • esvesdin
                        • Mar 2022
                        • 22
                        Re: ricoh mpc 6003
                        I believe this is a forum where technicians come up with a problem and other technicians offer a solution, usually when i put the original genuine units i don't have any problems so i don't need any forum and no help, turn two screws, put part, twist and voila . You should have offered me some opinion of the problem i was facing, if you may have a similar or the same problem
                        tenx for nothing
                        greetings
                          • 37560
                          Re: ricoh mpc 6003
                          tenx for nothing
                          greetings
                          And you should have provided a hell of a lot more information with you original post. We are not mind readers.You want an opinion? My opinion is that you are acting like a butt hurt idiot.
                          • sandmanmac
                            • 3985
                            Re: ricoh mpc 6003
                            tenx for nothing
                            greetings
                            I think I was pretty clear with my advice you ungrateful little man, but I'll try to be even more clear..
                            STOP USING SHITTY PARTS!........Problems solved!
                            • esvesdin
                              • Mar 2022
                              • 22
                              Re: ricoh mpc 6003
                              i tried with this exchange but problem is still there, now i take another opc unit i m going to repack part by parrt to see what the fuck is rong
                              greetings
