IMC6000 with strange module P/N
  • Raymond
    • Mar 2022
    • 24
    [Error Code] IMC6000 with strange module P/N
    I bought a new IMC6000 with SR3290 Finisher 3 months ago. When updating firmware using Ricoh Firmware Update Tool, it shows "Cannot be updated because it contains a custom module".
    When I try to update firmware (D0BN5596K.pkg, seems to be up to date) using USB pen drive with USB on SOP, after step 4/4, it shows"E86", which I found nothing about on Service Mannual.
    The firmware is as below. I find the P/N for Finisher is LR999999, Not Dxxxx as others.
    System/Copy 3.53 D0BN5551B
    Network Support 18.75 D0BL5578Q
    Web Support 3.02 D0BN5570V
    Fax 03.53.00 D0BL5560N
    RemoteFax 03.53.00 D0BL5562G
    Scanner 03.01 D0BL5568N
    Web Uapl 3.00 D0BN5572L
    NetworkDocBox 3.51 D0BL5574K
    animation 3.00 D0BN5576E
    Printer 3.52 D0BN5581R
    RPCS 3.23.15 D0BN5583C
    Font EXP 1.00 D2415581
    PCL 1.06 D0BL5584D
    IRIPS PS3 1.00 D0BL5586A
    IRIPS PDF 1.15 D0BL5588J
    IRIPS Font 1.15 D0AF5577A
    GraphicData 2.04 D0BN5591M
    MovieData 1.00 D0BN5561B
    MovieData2 1.00 D0BN5563B
    MovieData3 1.00 D0BN5565B
    Data Erase Onb 1.05 D2625244
    FCU 01.00.00 D0BW5778A
    PowerSaving Sys F.L3.23.1 D0BN5556C
    RicohACT 1.20 --------
    Engine 1.13:04 D0BQ5503L
    OpePanel -------- --------
    ADF 01.050:02 D3FF5260F
    Finisher 01.06A:07 LR999999
    Bank1 01.010:05 D3FY5260E
    What's wrong with this machine? How can I correct this or update firmware? Thanks!
  • Gift
    • Mar 2011
    • 2459
    Re: IMC6000 with strange module P/N
    I'm not aware of this custom firmware but did you try and unplug the finisher as a workaround or try the good old *.fwu/romdata files?
    • luca72
      • Oct 2017
      • 1762
      hello, it seems that you need the package D0BN5595Q Ver.4.60.1 2022/03/08, which specifies "(For overwriting temporally / customized FW)" ... for me the finisher has nothing to do with, that firmware version with the "strange" number, is making you take the wrong path
      "I'll be back"
      • Raymond
        • Mar 2022
        • 24
        Thank you very much. And new problem......
        Unplug and try update using RICOH Firmware Update Tool, it works, although SC792-00 pops out, means finisher cannot find, of course.
        Then download D0BN5596K.pkg again, successfully update to 4.59. Don't know why it isn't 4.60.1, which the Ricoh website shows to be up to date.
        After reboot using RFUT check again, it shows "Lastest". And with finisher plugged, the damn "Custom Module" comes out again.
        Plus, Don't have any good old fwu/romdata. I can only get firmware pkg from RFUT.
        • Raymond
          • Mar 2022
          • 24
          [ATTACH=CONFIG]52456[/ATTACH]
          Er.... Maybe you are right. But as I reply above, RFUT only get me to 4.59, then it shows "LATEST".
          I don't know any other way to get the package you said, don't know if it fit my IMC6000 (China market) neither.
          Thank you anyway.
          PS, cannot open your attachment.
          • Raymond
            • Mar 2022
            • 24
            Ah, forget to paste the new P/N here. If you can find anything unusual...
            Thank you for your help.
            System/Copy 4.59 D0BN5551F
            Network Support 18.82 D0BL5578T
            Web Support 4.02 D0BN5570Z
            Fax 04.59.00 D0BL5560S
            RemoteFax 04.59.00 D0BL5562K
            Scanner 04.01 D0BL5568R
            Web Uapl 4.02 D0BN5572Q
            NetworkDocBox 4.59 D0BL5574N
            animation 4.01 D0BN5576H
            Printer 4.59 D0BN5581W
            PCL 1.06 D0BL5584D
            IRIPS PDF 1.18 D0BL5588M
            GraphicData 3.01 D0BN5591Q
            Engine 1.16:04 D0BQ5503P
            • Gift
              • Mar 2011
              • 2459
              Glad we could help
              A theory why the update tool does not show the most recent FW you can get as a tech might be a precautionary decision. Even if a firmware is labeled as "final/stable" after internal testing there's a chance that problems can occure in the field and ricoh probably think that's "our" job (including the direct techs) to detect and report them before rolling them out to the update tool/arfu. Another possibility is that the person who's suppose to maintain the data for the update tool is one of the lazy kind^^
              Guess I wouldn't bother about this minor version gap anymore as long as everything is working well.
              • Raymond
                • Mar 2022
                • 24
                Yes, I'm so relieved and happy to see the update tool works, though not the most recent one. The new version will come someday sooner or later.
                Thus, what really bothers me is the wrong P/N.
                Seems I can't get any update version with finisher plugged, and can't update/fix finisher P/N problem with it unplugged.
                That IS a terrible endless loop...
                Any chance to bring the finisher firmware back on track?
                  • 37447
                  The firmware version of the finisher is the custom module. Follow luca72's recommendation, download and update with D0BN5595Q Ver.4.60.1 2022/03/08. That should bring the finisher to the proper version. If it doesn't, the next thing to try is updating the finisher with module firmware, not package. The next option would be to replace the EEPROM in the finisher. Worst case scenario is that finisher has a custom control board that will need to be replaced.
                  Once you have the custom firmware taken care of,you may need to update with D0BN5596K.pkg again or whatever by now is the most recent package to bring everything up to date.
                  • copier tech
                    • 8138
                    PCL 1.06 D0BL5584D
                    We have seen this issue a few times.
                    The best fix is to update the firmware package using the latest via SD card.
                    • luca72
                      • Oct 2017
                      • 1762
                      maybe that strange nomenclature has been put in place, as a signal to make it clear (who knows) that a custom firmware is present?
                      The best way to update, its ad card system, RFUT, work and not work...at Surprise...every time that i Need!
                      "I'll be back"
                      • sandmanmac
                        • 3981
                        Excellent Info!
                        I've run cross this a few times myself since I started using the Update tool.
                        It Will NOT work if there are ANY custom F/W modules installed, and since Pkg doesn't include accessory F/W files , it has to be done via an SD card with individual modules to overwrite the custom F/W
                        • Raymond
                          • Mar 2022
                          • 24
                          Thank you all for all your experience AND suggestions!
                          According to the service mannual, IMC 4500/6000 DO NOT support individual firmware, but ONLY pkg when using Removable Media (SD card and USB drive).
                          So, I did not try any *.fwu by now.
                          Another need to mention is that, I (and my dealer) did not install any custom F/W ever. Just bought 2 new IMC6000s the same time, then find one is OK to pass the RFUT check, the other one shows "custom module".
                          I guess there may be some software bug showing wrong P/N, not really Custom Module installed on the finisher, since finisher works well and no Error code pops out.
                          Via SD card using SD slot on the back? IS it different from using USB pen drive?
                          And may I use the D0BN5596K.pkg (4.59, the same version installed already) ? Thanks.
                            • 37447
                            NO! Use the version that luca72 suggested. D0BN5595Q Ver. 4.60. It was issued on the 8th to correct this exact problem.My guess is that Ricoh had some finishers with custom firmware get mixed in with the standard finishers. One dealership got one of them. Just be happy it wasn't both. If the 5595Q package cures the problem you should be fine going forward in the future.
                            Somewhere there is a customer for whom the custom finisher firmware was created who has gotten a standard finisher who might be upset when the standard finisher does not do the custom job properly. That to Ricoh will have to correct with a special firmware release.
                            • Raymond
                              • Mar 2022
                              • 24
                              Thank you very much! I must be much luckier than the poor guy who get a wrong finisher. At least, my finisher fit all my need by now.
                              But, first, how to confirm 5595Q fit my machine, won't make it brick?
                              Second, how to get this pack, except RFUT? I think this is the only way for end users to get firmware pack. Could you please give me a download link?
