scanner image whacked
  • digicor
    • Jul 2008
    • 1153
    20220418160907767_0001.jpg20220418161003450_0001 (1).jpgsee pics, is this something that can be re calibrated? ive taken the glass of and observed the lens/mirrors/ theres no obstruction
    • 23008
    Re: scanner image whacked
    Which way was main-scan & sub-scan on that image?
    It looks like the optics are unfocused, possibly at the CCD. If the blurry area is at the trail edge of the scan (original image LTR-R orientation on the glass), the adjustment is in the sub-scan direction (adjusting the CCD height up/down at the left/right). If the blurry area is at the front or rear edge of the scanner (original image LTR on the glass), the adjustment is in the main-scan direction (adjusting the CCD height up/down at the front/rear of the machine.
    Those are those red painted screws, but don't panic. Just keep track of the # of turns you make at each adjuster, in case you need to reverse what you did. It's a trial & error adjustment. Whenever I do it, I inevitably make it worse before I make it better.
    Start with 1/4 turn of the adjuster at a time, until you see if you've improved the focus or made it worse. When it gets close, reduce the adjustment to 1/8th turns, then 1/16th turns ... until it's perfect. =^..^=
    • digicor
      • Jul 2008
      • 1153
      this is a c5503 what red screws?
      • copyaction
        • Oct 2007
        • 991
        Tried lifting up on the front left corner of the scanner?
        • Debs1964
          • Oct 2010
          • 1693
          +1
          the image is trapezoidal, so the scanner is out of alignment, someone has leant on it
          There are 10 types of people in this world, those who understand binary maths and those who don't
          • tonerhead
            • Sep 2009
            • 582
            Agree with Deb. In olden days, you could pull off left scanner covers and push scanner to far left of machine and check for alignment. Not sure if still the case. The other thing to check is the leaf springs holding the mirrors in. Those could have been knocked out of place during cleaning. Back in olden days Ricoh used a glue that started to give away on ccd that would give a result like this.
            I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
            Especially when it comes to sex
            • tonerhead
              • Sep 2009
              • 582
                • 37487
                I have also seen lazy customer employees lean on the front of the machine while they are using it.
                • digicor
                  • Jul 2008
                  • 1153
                  its not just the doc feed scanner,its on the glass as well, but i have pushed the scanner to re align it before but it was for registration issues not this... and where are the lred scews ? i can find any red adjustment screws in or around the lens, or the whole unit, in the back, or at the lens? please advise
                    • 37487
                    When someone leans on the left front corner of the MFP it distorts the entire scanner frame,
                    • digicor
                      • Jul 2008
                      • 1153
                      gotcha
                      • tsbservice
                        Field tech
                        • 8013
                        Yep, that's why they put hard cardboards on new machines in this corner to support possible extra weight when machine is shipped or stacked.
                        I also really hate when someone pushes machine with hands on ADF...but people do it always.
                        • digicor
                          • Jul 2008
                          • 1153
                          okay thats the ticket, it was way bent down, and i bent it back, good quality, but, the scanner is definitely loose in the corner, i can just lean on it and it moves down,, any fix for this? i guess if the client doesnt do a butt shot it should be okay
                          • digicor
                            • Jul 2008
                            • 1153
                            also when i do an auto color calibration it fails,, no matter what, i had to re boot the machine to get the quality back
                              • 37487
                              Definitely sounds like a ID sensor problem.
