MPC 307 faulty test sheet
  • dave w
    • Jun 2015
    • 230
    I think I have done about all I can do - im failing on this one
    Company bought machine ( as new ) on Colour = 300 & K = 200 - was told toner hopper was faulty which it was
    what had been done
    New K toner hopper & toner motor
    all firmware updated
    Manual Pro Con
    Vsg reg front center rear = 4.93
    TD sen Ini set result - 1111
    TD sensor clean
    changed TD sensor
    all parts listed below moved to another working machine and all was good, no visible issues on test sheet =
    PCU's
    ITB
    Fusing Unit
    Registration Roller
    Laser Unit
    Am I missing something?
    Thanks in advance
  • mikadonovan
    • May 2008
    • 2931
    Re: MPC 307 faulty test sheet
    I would say make sure the LD shields and ID sensors are clean first. Perform a forced toner supply on all colors. Run ACC. You also may have to reinitialize K developer after you achieve a good K solid from the forced toner supply.
    NEVER ASSUME ANYTHING
    • GIUBOSS
      • 1436
      Perform SP2-111, Forced Line Position Adj., All steps.
      • dave w
        • Jun 2015
        • 230
        BIG thanks
        Will try that on Monday as I dont work Fridays.
        Dave w
        • dave w
          • Jun 2015
          • 230
          Big Thanks
          I did run d after new laser unit was changed, will revisit that option
          Im thinking thats its not a hardware issue and just something i dont know about or missed
          Thanks agin
          Dave
          • Mark Bbb
            • Jun 2012
            • 1662
            If client doesn't complain, let it be
            • dave w
              • Jun 2015
              • 230
              Its going into a Nursery where they print photos off for the perants.
              you can bet your bottom dollar - they will notice.
              It shows up at the top of the page if text is presant, and the client is in London which is miles away from where we are on the coast.
              Dont fancy a revist
              Dave w
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                Originally posted by dave w
                [ATTACH=CONFIG]53194[/ATTACH]
                what had been done
                Manual Pro Con
                TD sensor clean
                changed TD sensor
                PCU's
                ITB
                Fusing Unit
                Registration Roller
                Laser Unit
                Thanks in advance
                Hi dave one of the problems you have when you use pcdu's from another machine they don't set up unless you run manually also toner hopper problems always give you faulty add toner sign I would check the pm life's. Do forced line adjustment in correct order. Also if you require I could always have a look for you i'am based in London. Also if you did do toner hopper you would of removed laser ribbon cables hopefully they not damaged
                Regards Mark
                • dave w
                  • Jun 2015
                  • 230
                  Thanks for advice mga
                  Machine is in the workshop getting ready for install, possible next week ( tuesday 09/05/2022 ) so pressure is on!
                  will keep you in mind
                  Dave w
                  • luca72
                    • Oct 2017
                    • 1784
                    what had been done
                    Manual Pro Con
                    TD sensor clean
                    changed TD sensor
                    PCU's
                    ITB
                    Fusing Unit
                    Registration Roller
                    Laser Unit
                    Thanks in advance
                    changed all that stuff, and don't go?
                    try while printing to keep the door closed with one hand, pushing hard ... and see what happens, maybe it doesn't close well (?)
                    "I'll be back"
                    • dave w
                      • Jun 2015
                      • 230
                      Good call - BUT still the same.
                      Thanks anyway
                      • dave w
                        • Jun 2015
                        • 230
                        Thanks to all
                        Went through everything you guys advised - the Test chart is better and doent show any symptoms when printing text.
                        Thanks again
                        Dave
                        • Vegas Biker
                          • Sep 2020
                          • 8
                          Hello!
                          This post might be too little too late and if so I'm sorry...I don't get a chance to hop on here very often.
                          Question...the page you posted, was it printed short edge feed or long edge feed? If long edge feed, then your K PCDU is the problem. Developer could be clumping up and clogging up the brush. Fix action is to take a piece of plastic (about the thickness of an ID badge or credit card) and stick it in the gap between the drum and dev unit and swipe it back and forth to break up the developer.
                          I had this same issue with an IM C3500 on the K PCDU. I printed a checker pattern test page for all 4 PCDUs and it was only the black that had voids and faded prints. (much like the bottom corner you circled)
                          I did what I recommended above and it prints like brand new again.
                          Credit goes to a guy on youtube that I stumbled across researching the problem.....I forget his name though.
                          Cheers!
                          • sandmanmac
                            • 3981
                            Originally posted by Vegas Biker
                            Hello!
                            Cheers!
                            The C307 is ONLY capable of printing SEF.
                            He clearly stated that basically ALL parts work perfectly in another machine.
                            The solution you provided sometimes helps if there is a distinct blank line on the image due to 'toner rocks', but that's not the case here at all (he circled BOTH corners)
                            • dave w
                              • Jun 2015
                              • 230
                              Thanks Vegas Biker
                              Yes the card slide trick, was shown that some years ago and works well when you can see a line on the mag roller.
                              Dave w
