Ricoh mp c3004 , blocked
  • tullio
    • Feb 2012
    • 268
    as soon as it is turned on, this error is thrown.
    Has anyone happened?
  • UNICORNico
    • May 2018
    • 308
    Re: Ricoh mp c3004 , blocked
    Originally posted by tullio
    [ATTACH=CONFIG]53234[/ATTACH]
    Most likely you have corrupted data on the HDD, or it is damaged.
    I recommend that you turn on the device with the HDD disconnected from both its data power and power supply. And try turning on the device.
    If the boot is "normal", we can rule out control board problems.
    "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
      • 37533
      SC 672-00 is a communication error between operation panel and the controller after machine is powered on. Biggest cause over the years has been the USB cable between the controller and the operation panel, frequent just a loose connection at one end or the other. Could also be a defective controller PCB.
      • luca72
        • Oct 2017
        • 1784
        as a first indication I would look at the lighting condition of the row of LEDs on the controller board, for example: if they are all on, or all off it is bad! ... almost certainly the controller is gone
        "I'll be back"
        • GIUBOSS
          • 1436
          Are you a technician or a user?
            • 37533
            With as long as he has been around, I would say tech. With as many red cards that he has accumulated I would say not a very good one.
            • GIUBOSS
              • 1436
              I think
                • 8174
                Before replacing ANY boards re-seat all connections to the controller especially the USB cable that runs to the control panel.
                Then update ALL firmware. If the machine won't accept a firmware update via SD card then most likely the controller board has failed.
                Troubleshooting - SC672-00 to 13.pdf
                • tullio
                  • Feb 2012
                  • 268
                  Hello. I'm a technician. thank you . now I do some tests.
                    • 37533
                    Start with reading and understanding the service manual.
