Mpc2051 - half page have bad toner transfer
  • luca72
    • Oct 2017
    • 1750
    Hello everyone, today I visited a customer with mpc2051, I state that he had not explained the defect well, and I had only common spare parts with me.
    practically prints half sheet with bad transfer from belt to paper (not random).
    I disassembled and checked the complete itb, I replaced the PTR roller, I stopped the mc during printing, at the point of the defect, and the image on the transfer belt is there, so it's half an image does not transfer to the paper
    I also tried to change the socket, you never know, some electrical noise, but nothing
    I'll be back tomorrow with:
    -ITB complete unit (used)
    -complete PTR unit with stand, and all (used)
    - PTR approach mechanism / motor. (used)
    -power pack TTS (pcb16)
    if you want to suggest me something else, welcome
    has it already happened to someone?
    "I'll be back"
    • 37395
    Re: Mpc2051 - half page have bad toner transfer
    [ATTACH=CONFIG]53393[/ATTACH]
    It has been years since I have worked on a C2051, but they had a tendency of breaking PTR latches allowing pressure on one side to be reduced.
    • 8T2
      • Aug 2015
      • 257
      Cursed by working on a site that still has a boatload of these and 99% certain you have a busted transfer lock lever
      D0396229 LEVER:SET:FRONT
      D0396230 LEVER:SET:REAR
      Usually it's just the little tabs on the levers that snap off and I got tired of replacing them and started repairing them by making my own tabs, if the ring didn't split, with a product available over here called Q-Bond, basically good quality superglue/crazy glue that comes with its own powders but glue and bicarbonate of soda or salt does a good enough job too.
      Make sure both springs are still present too because they somehow disappear whenever the levers break.
      Sent from my SM-A305F using Tapatalk
      • luca72
        • Oct 2017
        • 1750
        Hello, I understood what you are talking about, at the beginning I changed them too, then since even from new they have the tendency to freeze giving boredom to both me and the customer, I started to remove the whole mechanism, spring, hooks, levers, everything in short, everything is close with the duplex, (mp4000 style) and on dozens of machines, I have never had any problems, this problem, least of all.
        "I'll be back"
        • dalewb74
          • Feb 2018
          • 1135
          clean ITB sensors?
          • luca72
            • Oct 2017
            • 1750
            Originally posted by dalewb74
            clean ITB sensors?
            Yes, clean First of reinstall the itb
            "I'll be back"
            • 8T2
              • Aug 2015
              • 257
              I honestly never tried it with both levers removed. I was afraid it will cause equally light prints on both sides but now that you mention it it makes sense that it won't raise the 1 side if there is no lever/spring applying pressure on the other side. Will give it a try next time thanx
              • 8T2
                • Aug 2015
                • 257
                Off topic but the duplex open/close gate that always breaks on these can also be removed completely in lots of cases and the machine works fine. Still trying to pinpoint the cause on the machines that don't want to work without it installed but these days I just remove it and will only replace if it causes problems
                • luca72
                  • Oct 2017
                  • 1750
                  hi, this morning I went back to the customer, and I replaced in sequence, one at time a follow part
                  - complete PTR unit (used) = NG
                  - transfer & PTR HVT board = NG
                  - complete ITB unit = quasi ok
                  in the end it was almost okay, but on the one hand there was still a bad transfer.
                  so, I broke my balls, and we decided to replace the machine with another 2051 that I am overhauling now.
                  unfortunately time is money, so we preferred to avoid other exits.
                  thanks for your cooperation, see you next time
                  "I'll be back"
                  • UNICORNico
                    • May 2018
                    • 308
                    I had a similar case just over 1 year ago, with an MPC2030. The defect was very similar, but in my case it was all over the page and I did it in a staggered way (like a pedestrian crossing).
                    It turned out that the transfer band was replaced and installed incorrectly, in the orientation that it was not. I was required to disassemble the entire ITB, put the transfer belt in the correct orientation, take advantage and clean all the rollers to ensure both traction and avoid impurities, which will affect the quality.
                    The problem was fixed.
                    "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
                    • GIUBOSS
                      • 1395
                      check if the paper is damp
                      • luca72
                        • Oct 2017
                        • 1750
                        no, it is a very dry environment, then the machine has been there for 4 years, now that we replace it with another mpc2051 revisionated, I bring that here to the laboratory, and I will find out what the problem is, (I have here 4 mpc2051 semi-complete for try parts)
                        "I'll be back"
                        • luca72
                          • Oct 2017
                          • 1750
                          And you were right man, after several tests here in the laboratory, it turned out that the machine had a double problem, the first was the ITB with some elettric dispersion, I'll investigate, the second problem was just those two plastic hooks, the thing is really strange, because as I said I usually remove all the mechanism, and I never had any problems, even the one we had here last year in administration, without hooks and mechanism, I myself have printed some photos of excellent quality
                          anyway thank you all for your cooperation
                          "I'll be back"
