ricoh mp c2003 , jam .
  • tullio
    • Feb 2012
    • 268
    Hello. i replaced the fuser, same problem. someone has this problem? thank you.
    WhatsApp Image 2022-05-25 at 20.08.24.jpgWhatsApp Image 2022-05-25 at 20.21.15.jpg
  • luca72
    • Oct 2017
    • 1711
    Re: ricoh mp c2003 , jam .
    [ATTACH=CONFIG]53411[/ATTACH][ATTACH=CONFIG]53412[/ATTACH]
    paper exit unit sensor, item 56 on attachment, (there are 2)... but for sure try to replace the complete paper exit from other machines , if you have.
    i suggest you to clean exit paper roller, and contro-roller, and check that all shaft are free to rotating in the various bushing
    • StephenB
      • Aug 2015
      • 238
      Best to replace the entire exit assembly and sensors, I have come across several guides which are warped causing this type of jam
      • UNICORNico
        • May 2018
        • 308
        Although it requires more time, I disassemble the "Output Unit", replace the deformed guide (usually by the temperature of the fuser) and check all the axles and clean all the wheels / conveyors of the paper.
        Some time ago, in an incident, partially lower the fuser temperature and clean the ozone ventilation areas, since the problem was repeated 3 times in less than 2 months. And it has not happened again, after doing this last process.
        "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
          • 8121
          If it jams every time check each sensor using input/output check in SP mode. Check each sensor changes from 1 to 0 when you put your finger over it etc this will identify which sensor has failed, or rule them out as being OK.
          • emiliorsg
            • Jul 2018
            • 141
            Check the guide plate of the fusing exit. I have found several very deformed by temperature.
            • luca72
              • Oct 2017
              • 1711
              hi, I have tried several times "output check" on that problem of that paper output model, but unfortunately it is not reliable, as the problem is not fixed, but it is sporadic and occurs during operation (at least, to me it was always like this, those 4-5 times) so it is almost impossible to catch the sensor at fault
              • luca72
                • Oct 2017
                • 1711
                hi, I thought too, there is a bulletin, about the deformation of the fuser palstics, but our friend tullio, says that he has replaced the complete fuser, so if he is not really unfortunate, it is really difficult to catch two fusers with the same defect
