MP3352 Not Fusing 1st few Pages
  • laser801
    • May 2014
    • 148
    Ok, Ok, Here we go! I have a couple Mp3352,s out in the world that are not fusing the toner only on the first 2-3 pages when they start using the machine after awhile...I have changed out the Fuser Units and Drum Units several times and no change...I'm pretty sure there is a setting that will correct this (Fuser Idle Temp) ??? Its just strange to me why on just a couple of these when I probably have over 30 of these units out there ??? Actually, this is the first time I have seen this issue, where it will do it only when it starts up... Anything you have will be MUCH appreciated ! Thanks! Laser801
  • sandmanmac
    • 3963
    Re: MP3352 Not Fusing 1st few Pages
    Yup.
    Turn on Fuser Idling.
    SP1103-1 (Set to "1")
    I've only ever had to do it in a handful of locations myself, but it's almost always been in a place that's a little cool.
    I think it can also be caused by some types of generic heat rollers where the metal is a bit thicker, and possibly even if you're using a 3351 Hot roller in the machine vs. the 3352 which actually is a little thinner I believe (?)
    • TonerMunkeh
      Professional Moron
      • 3865
      Running aftermarket toner is a good cause for this too.
      Hit it.
      • luca72
        • Oct 2017
        • 1677
        maybe a cocktail of dirty/defective thermistor, and bad paper thickness settings (?)...even in fuser shutdown mode, it doesn't have to make that defect, under standard conditions
        • laser801
          • May 2014
          • 148
          Originally posted by sandmanmac
          Yup.
          Thanks for your reply... I'm heading there now to give it a go... That unit is in a damp basement so what you're saying could be right on.
          • laser801
            • May 2014
            • 148
            We are running a good quality aftermarket toner... I have many of these units out there running on the same toner... Hopefully this 1103 setting will help. Thanks so much for your reply!
            • laser801
              • May 2014
              • 148
              Thanks for your reply... I will take that into consideration... I did put a fully rebuilt fuser in. Paper could be an issue. Machine is in a damp basement as well...
                • 36807
                You may need to install the optional tray heater(s).
                • luca72
                  • Oct 2017
                  • 1677
                  feel if it can be useful to you, I remembered that once on mp2000, I had the exact same problem, a worker was doing some work on the sign outside with a big drill, not the usual ones we have in the garage, it was monstrous, and when he drilled, the fuser unit was leaking power, and the image dont are fixed, only in those moment
                  then check the power outlet .... and while you're at it bring a power board, maybe that has the triac that hesitate when cold (?)
                  • luca72
                    • Oct 2017
                    • 1677
                    feel if it can be useful to you, I remembered that once on mp2000, I had the exact same problem,a worker was doing some work on the sign outside with a big drill, not the usual ones we have in the garage, it was monstrous, and when he drilled, the fuser unit was leaking power, and the image dont are fixed, only in those moment<br>
                    • DRichard
                      • May 2008
                      • 482
                      Yeah. Second that. My vote is air conditioning and/or humidity issues. I would guess these copiers might be rather close to HVAC vents.
                      "Enjoy every sandwich."
                      -- Warren Zevon
                      • rthonpm
                        • Aug 2007
                        • 2847
                        Humidity can cause all kinds of fusing issues, and it sounds like this is definitely an environmental issue. The tray heater i going to save you all kinds of grief with this account.
                        • KeviM
                          • Oct 2019
                          • 324
                          • KeviM
                            • Oct 2019
                            • 324
                            Also, 1 more thing
                            Your toner needs to be of good quality.
                            Poor toner can have a bad melting point and cause the problem you having.
                            Perhaps it's a bad batch of toners? We use alot of high quality generic toner at our office. Last year a really good brand had a bad batch. That cost us thousands and lots of downtime...
                            All I'm saying is sometimes even the good toners go bad
                            All the best friend
                              • 36807
                              There is only one quality aftermarket toner/developer that I have ever encountered and it is just as expensive as Ricoh's.
