pro c5200 white lines only on copy only
  • Marwanalhajbi
    • Jul 2018
    • 72
    i have a pro c5200s have an issue of huge white lines on copied paper,i have cleaned the mirrors no hope
    i have attached a sample 5200.pdf
    any ideas?
  • anothertech
    • 1762
    Re: pro c5200 white lines only on copy only
    Clean both sides of the slit glass in the scanner. Then clean the standard white ref plate on the bottom left edge of the platen glass. Then run Auto Color Calibration.
    • Marwanalhajbi
      • Jul 2018
      • 72
      Originally posted by anothertech
      clean both sides of the slit glass in the scanner. Then clean the standard white ref plate on the bottom left edge of the platen glass. Then run auto color calibration.
      i have done that,no result
      • UNICORNico
        • May 2018
        • 308
        i have attached a sample [ATTACH]53676[/ATTACH] any ideas?
        Can you confirm if it is only to the copy and not to the print?
        SP Printer 1-103-002 and tell us if the printer pattern is also correct.
        You may have a problem in the Development Units.
        "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
        • DRichard
          • May 2008
          • 482
          any ideas?
          "White lines" indicate VOID streaks so I seriously doubt your problem is with the scanner. Check drums/dev units or laser exposure being interrupted.
          "Enjoy every sandwich."
          -- Warren Zevon
          • Marwanalhajbi
            • Jul 2018
            • 72
            it is correct however when i do calibration it fails ,saying put the paper correctly on glass.
            then it asks to start allover again .
            • Marwanalhajbi
              • Jul 2018
              • 72
              it won't make calibration from scanner, saying put it correctly on glass ,i do that correctly but it keep giving me failed
              • davel
                • Oct 2011
                • 1095
                Clean the entire optics properly.
                • satins
                  • Feb 2021
                  • 89
                  any ideas?
                  How did you develop this issue.
                  Does it happens when you scan via platen glass too?
                  Was it a gradual process or it just happened in just one day?
                  Did you develop this after cleaning your machine?
                  If it is only related to copy and you have cleaned the mirror then it opens up communication problem with image sensor.
                  Have you tried working on the IPU and DF communication wire, camera?
                  All of this will only make sense if the issue has been isolated towards scanner?
