MP C3504 noises
  • ABS tect
    • Sep 2013
    • 511
    MP C3504 noises
    Today seems like a day for obscure '04 noises so I thought I would share my current headache.
    My 3504 makes this very fast clicking noise ONLY at the very beginning of a print/copy job and then right at the end. If I do a 10 page copy job, right when I hit "start" you will hear it as the paper begins to feed, then nothing for the rest of the job until the very end when the job is finishing up.
    I can't recreate the noise in 5-804 while turning all the motors. Seemed to me like maybe a paper feed motor but i already swapped out the paper feed motor, transport motor, and registration motor and I haven't yet but I'm about to do the PCU: Black/Image Transfer Motor (even though I get no noise while turning this in sp mode).
    Figure it may have something to do when a clutch engages at the beg/end of job.
    When I have the back open and running, the noise seems to be coming from very near the PCU: Black/Image Transfer Motor (if that's it I apologize for jumping the gun on this post) but I don't think that's it.
    For the heck of it we replaced the ITB, K PCU, and Fuser as well.
    Any guesses?
  • luca72
    • Oct 2017
    • 1791
    Re: MP C3504 noises
    Any guesses?
    Could be a waste toner bottle agitator, like a developer black agitator noisy...or the black toner its empty, (the empty toner bottle make more noise) and the machine do some toner load shot, toner Hopper black unit noisy
    "I'll be back"
    • MIKON
      • Jul 2015
      • 188
      Re: MP C3504 noises
      Does it make noise in B/W or color or both?
      • anothertech
        • 1771
        Re: MP C3504 noises
        Did you replace the waste toner bottle?
          • 37560
          Re: MP C3504 noises
          cibergoose, you need to learn how to properly Reply with Quote. Otherwise your post is pure gibberish. Until you learn how to do it properly, DO NOT TRY TO INSERT YOU COMMENTS INSIDE THE TEXT OF THE POST YOU ARE REPLYING TO.
          • UNICORNico
            • May 2018
            • 308
            Re: MP C3504 noises
            Any guesses?
            "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
            • emiliorsg
              • Jul 2018
              • 141
              Re: MP C3504 noises
              Check that the waste container is not full and if it is, check the sensor.
              • ABS tect
                • Sep 2013
                • 511
                Re: MP C3504 noises
                Thank you all for your replies...I changed out the PCU/Image transfer motor and waste toner tank with no luck.
                Upon further disassembly, the gear that the development solenoid touches I believe is the culprit (couldn't really tell off the SM what that part was called, maybe that is the dev. agitator that was mentioned).
                However, whatever it is, is in the main drive assembly, and like was stated, some noises live and die with a machine. It is not the worse noise ever so I may just button her backup and keep this machine in my back pocket for a specific purpose where that noise will not be a bother. Because other than that noise, this machine is great.
                I appreciate all the reply's so quickly, you guys are great.
                • luca72
                  • Oct 2017
                  • 1791
                  Re: MP C3504 noises
                  Infact, there Is also a bullettin that speak about possibile noise from the front agitator of developers units, (the Little box with two White plastic Gear in front of developer unit)....but never happened ti me...you can try to remove One Gear momentaring for test
                  "I'll be back"
                  • tonerhead
                    • Sep 2009
                    • 582
                    Re: MP C3504 noises
                    Agree with this. It all depends what developer assy you have. I think Ricoh realized their error and phased these out. The tapping sound is probably normal for the developer assy. Their theory was the "tapping" would prevent the dr blade from clogging and giving voids. Up to you, but I think you can just remove the gear and let it buck. I only had one doing this back when and after I figured it out, told the customer this is normal.
                    I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
                    Especially when it comes to sex
                    • luca72
                      • Oct 2017
                      • 1791
                      Re: MP C3504 noises
                      it could be that its knocking mechanism (rtb1) is a little louder than usual, it could possibly inspect it, it doesn't seem complicated to me, or during installation, the internal mylar protection (rtb2) did not rewind well, or completely, and something touches it during rotation
                      "I'll be back"
