Scan to folder - ubuntu vs mpc 2051
NEVER ASSUME ANYTHINGComment
Re: Scan to folder - ubuntu vs mpc 2051
Another thing you might try is change file permissions by sudo
chmod ugo+rwx foldername where foldername is the name of your folder in command line or in gui right click on sharefolder, properties, permissions. Set all three usergroups to read, write, execute.I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
Especially when it comes to sexComment
Please start you post with brand, model, problem.Comment
Then you’re plain stupid, pardon my french. When you stand inline at the cash register in the supermarket, paying for your purchases, will you say “I can’t really give you any money, cause I work for free.”
MAKE THEM PAY! Also you’re undermining all of us taking payment for our labor time.
then he did not understand anything of that i wrote, I said that I am doing it because it interests me, in this context of linux sperimentation, the customer didn't ask me for anything, I offered myself...and then and 100m from my house, I do not go around repairing machines for free, or for a fee, I do not need it"I'll be back"Comment
hi, yes, I did a series of tests with the user already present on ubuntu, and then I tried with one created by me (scanner, with password scanner), but neither of them worked, plus this morning I installed on the company pc ubuntu on virtual machine, and scan to folder on our mpc6003 I tried all the suggestions given to me by friends here on the forum, and it gives me the exact same error in wim .... but I don't give up! I have to do!
negotiation error by wim registry
#[smb client(4116)]22/07/07 09:52:48 SMBC: Access denied. [Unknown Cmd(0x05):445:0xc0000022] (05205) ERR:"I'll be back"Comment
Silly question: Can the 2051 scan SMB to a Windows PC? (with SMB1 disabled, of course).
It would be good to eliminate that as a possibility.“I think you should treat good friends like a fine wine. That’s why I keep mine locked up in the basement.” - Tim HawkinsComment
$ sudo apt install wireshark
How to Install and Configure Wireshark on Ubuntu 20.04
Once installed, start Wireshark, attempt scan to folder, stop Wireshark after error. Find first SMB packet from MFP, right click, and 'Follow TCP Stream"
Close the packet detail window which pops up to display the filtered SMB conversation.
Screenshot and post and maybe we can stop guessing here."Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
I know where you are coming from, however, sometimes there is more value in learning and customer care than what you gain in billing. I used to be pretty sharp at repairing connectivity issues and taking care of customer IT. Now different policies in place. Can't touch pc's anymore because we have an IT helpdesk that bills for everything. So out in field, customer asks simple connectivity question, most techs have deer in headlight look on face. Most reply I do hardware only, call our helpdesk. Customer calls for general questions, standard response is we are willing to help for $$$. The only solution is to include connectivity services with maintenance contract. To do this would require raising rates which is fine if competition does the same, but that will never happen.
The end of any profitability in this industry ended when contracts started including toner 20+ years ago. My employer is finally getting around to forcing sales and customers to sign an agreement that there will or will not be connectivity support on the contract. Most sales tap dance away from the issue as they are bidding on lowest pricing just to get the bid. Now mgmt is forcing sales to devulge this to the customer before order is signed rather than hiding it in the details. I have no problem billing these customers. It's the ones in the gray areas where sales just fails to mention no connectivity support, those are the ones you piss off.I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
The end of any profitability in this industry ended when contracts started including toner 20+ years ago. My employer is finally getting around to forcing sales and customers to sign an agreement that there will or will not be connectivity support on the contract. Most sales tap dance away from the issue as they are bidding on lowest pricing just to get the bid. Now mgmt is forcing sales to devulge this to the customer before order is signed rather than hiding it in the details. I have no problem billing these customers. It's the ones in the gray areas where sales just fails to mention no connectivity support, those are the ones you piss off."I'll be back"Comment
In terminal, if you go to the folder containing the one you created for sharing, enter ls -la and see what the permissions for the scan folder are. This will also give you the owner of the folder.
Sent from my BlackBerry using TapatalkComment
